Ohm TRS218 Replacement drivers |
Ajsski99
Registered User Joined: 07 October 2019 Status: Offline Points: 134 |
Posted: 21 January 2022 at 5:25pm |
Hi all,
May be getting my hands on a pair of Ohm TRS218 - unloaded What’s a decent driver to get to load them up with? Cheers
KDW32
Young Croc Joined: 09 April 2010 Location: Green Hell Status: Offline Points: 540 |
You can get the correct ones from OHM still. If your cabs are MK1 then the driver mounting hole pattern will be slightly out but is easy to adapt.
Ajsski99
Not really planning on loading them with Ohm drivers, was wondering what my other options were eg Eminence PD Oberton etc...
