  New Posts New Posts RSS Feed - Old Pro Audio Parts advert
PISSHEAD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PISSHEAD Quote  Post ReplyReply Direct Link To This Post Topic: Old Pro Audio Parts advert
    Posted: 17 September 2009 at 4:32pm
Found this advert in 'music mart' magazine showing some earlier Void equipment. (double click picture to make bigger)
Edited by PISSHEAD - 17 September 2009 at 4:34pm
The 'drunken master' strikes again.
levyte357 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 17 September 2009 at 5:01pm
Would be great if those V18-600 were still for sale.
Void Acoustic V-18 600 Driver
Designed for use with reflex and bandpass enclosures the V-18 600 has a 4" voice coil and a power handling of 600 watts rms. Sensitivity 96.70 dB 1w/1m
Void Acoustic V-18 Driver
TS parameters :
Fo 34.5 Hz
Qts 0.3345
Qms 14.0365
Qes 0.3427
Vas 253.3952 Litres
BL 25.0433 TM
no 2.9441 %
Sd 0.1230 sqM
Xmax 8.75 mm
Pwr 600 watts rms
Cms 117.9479 uM/N
Mms 180.1057 grams (Total Mass)
Mmd 155.3015 grams (Diaphm Mass)
Re 5.5000 Ohms
Le 1.1662 mH at 20KHz
Le 2.3803 mH at 1KHz
Zo 230.7808 Ohms
Rem 8.4826 Ohms Res at 1KHz
Rem 45.3728 Ohms Res at 20KHz
Krm 63.4521 mOhms
Kxm 19.1083 mH
Erm 0.5598 (Resis Expont)
Exm 0.7618 (Resis Expont)
Coil Size 100 mm (4")
Suspension Double Spider
Cone Type Paper / fabric surround
Dimensions 460 x 178 mm
Net Weight 11.8 Kg
Heathrow_B_line View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heathrow_B_line Quote  Post ReplyReply Direct Link To This Post Posted: 17 September 2009 at 5:33pm
they look like sound king drivers
studio spares still sell them, they soundok i think
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 17 September 2009 at 5:52pm
What's more surprising is the advert for the V18-1200 X !
rich_gale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rich_gale Quote  Post ReplyReply Direct Link To This Post Posted: 17 September 2009 at 6:38pm
i remember that advert.  how long ago was that? seems about 3yrs ago to me.
Static Age View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Static Age Quote  Post ReplyReply Direct Link To This Post Posted: 18 September 2009 at 10:08am
Even better if they were still £120. I think that add must be over 5 years old, maybe older. Can anyone remember the exact reason for the V18-600 being scrapped?
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 18 September 2009 at 5:06pm
Think it's older than that, the Stasys 3 Mk2 was available in 2005 as far as web.archive.org is concerned?
