Old voice coil as dummy load |
Author | |||
monkeypuzzle
Young Croc Joined: 25 January 2005 Status: Offline Points: 923 |
Posted: 10 July 2020 at 7:19pm |
Am i right in thinking I can do this? I've got some battered old who knows what drivers of about 4-600w with 3" VCs that are taking up space. At the most I'm dumping 190w into them. I'm just thinking of ripping it out and desk mounting it and maybe putting an old computer fan on it.
Is this a daft idea?
M4trix
Registered User Joined: 23 June 2009 Location: Croatia Status: Offline Points: 445 |
What ? You can't find a 4-8R/300W resistor ?
monkeypuzzle
I’ll take that as a just go ahead, what’s the worst that could happen
Digbethdave
Registered User Joined: 16 November 2018 Status: Offline Points: 406 |
What drivers are you going to hack up?
Earplug
Just make sure that you don't overheat them. Your standard large dummy resistor comes on a former which helps dissipate the heat. Likewise the coil and the speaker magnet, etc. You could fit the coil on some sort of heatsink - and definitely add a fan or two. Edited by Earplug - 11 July 2020 at 6:25am |
monkeypuzzle
Just some un branded pressed steel things that are probably at least 20 years old. We have a sheet roller at the workshop so I’ll roll an ali tube to sit snugly inside with a fan to cool. Cheers.
odc04r
I wouldn't personally, unless you potentially don't mind losing whatever was connected to them under test if they melt. Voicecoils are not the hardiest things even with cooling.
If you dumped them in a bucket of oil they'd be ok. |
Earplug
For frying chips? |
Peter Jan
Young Croc Joined: 16 December 2008 Location: Belgium Status: Offline Points: 1019 |
Yup and if you put enough power through that coil, you probably could really fry chips in it Edited by Peter Jan - 11 July 2020 at 9:58pm |
njw
Old Croc Joined: 26 March 2010 Location: S. Wales Status: Offline Points: 2572 |
^^This, chuck them in a bucket of old engine oil, if engine oil can dissipate heat in an internal combustion engine which has an actual fire inside it then a voice coil shouldn't cause a problem... :)
M4trix
But...but without water cooling the engine would blow its top !
njw
Quite right, although if there were no oil in the engine it would die a lot quicker than if there were no coolant in it...
