  New Posts New Posts RSS Feed - Omega Pro 18A
Omega Pro 18A
RealitySound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RealitySound Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2013 at 3:15am
You do realize that a g-sub is the same size as one full scoop.
When you gonna send me some $$ mate ?
shockwavesoundz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shockwavesoundz Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2013 at 3:20am
yea i like the height but its about 8 inches slimmer which makes a difference depending on where i go
Adam_Iron_Horse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam_Iron_Horse Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2013 at 9:10am
Why not sell these drivers and buy 8 better quality drivers that would be suited to the g-sub?
basshead2012 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote basshead2012 Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2013 at 9:50am
why just not build 4 C subs (plans off this site ) stick full grills on the front a pair each side stacked one on top of the other and build a couple of nice 12'' + 1'' tops with matching grill to sit ontop. then you can scale various size rigs e.g. 4 C subs a side with a pair of tops a side for bigger gigs
ceharden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2013 at 10:19am
As a slight variation on the GSub, you could go for building single designs such as the B&C Sub18 or 18Sound Kit18 design (both quite similar).  Or modify the designs for your own purpose.
Single designs will give you much greater flexibility in stacking, especially if you're doing more corporate work, different venue sizes.  For example 3 singles on their sides tends to give the ideal stacking height for mid-tops in many cases.
rish View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rish Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2013 at 12:15pm
+1. i dont see the need for building dual cabs.
DMorison View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMorison Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2013 at 12:55pm
+1 to this.
If you want to stay Eminence, even the Sigma would do better than the Omega in  G-sub style box. Despite its lower power handling it has more useable Xmax, and is cheaper to start with so you should be able to get a reasonable quantity for the $ you'd get for the Omegas.
David.
Dub Specialist View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2013 at 1:08pm
my days DM
just check ts/prams and yes sigma more xmax ect never realised allways thought thay were more or less the same driver just omega got bit more power,
Post Options Post Options   Thanks (0) Thanks(0)   Quote shockwavesoundz Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2013 at 1:25pm
Thanks for the replies guys....im looking at the Sigma pro's ya'll recommended and they do look good....would the difference in wattage be an issue or is the 150 watts fairly negligible? I had some 600 watt seleniums and they didn't last at all....i just realize they only have an xmax of 3.8...i was wondering why they tore up like that lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2013 at 1:41pm
If you went with a fairly standard single 18" reflex design you could use the Omega's if that's what you have available immediately, then upgrade to a higher performance reflex driver later.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMorison Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2013 at 4:23pm
800W vs 650W is less than one dB more power, so even if each driver could use exactly its rated power before reaching Xmax, you probably wouldn't even notice it (all else being equal).
Given that the Omega can't use most of its available power without running out of excursion anyway, the useable output of the Sigma, with each driver powered up to Xmax, should be 2-3dB higher.
David.
t.geessounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote t.geessounds Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2013 at 8:08pm
so what u guys saying is that the omega is a used less driver??
