Omnidrive on Martin audio Blackline |
dancefloorwizard
Registered User Joined: 02 September 2009 Location: Blackpool Status: Offline Points: 223 |
Posted: 09 April 2019 at 9:08pm |
Does anybody have any Settings. Im running a MA F12 and S15 using an omnidrive and some crest amps.
Thanks Rick Edited by dancefloorwizard - 09 April 2019 at 9:08pm |
dancefloorwizard
Also how will the omnidrive sound in comparison to using the Martin controller?
Edited by dancefloorwizard - 09 April 2019 at 10:00pm |
jacethebase
All the settings are on the MA website :)
www.stage2sound.com |
toastyghost
They are, but they're just taken from their own controller, which will use different maths to every other one. If you just type them into another unit, it will be wrong. Q and magnitude usually needs to be changed, as does the frequency.
dancefloorwizard
Can anybody help with the correct settings then for an omnidrive?
spongebob
Young Croc Joined: 20 October 2010 Status: Offline Points: 1395 |
Whilst Kyle is correct, in this case the General Presets spreadsheet available on the Martin Audio website contains a settings tab that allows you to change the processor being used, in this case from the default XTA setting to BSS.
https://martin-audio.com/support/loudspeaker-settings Download that, then enable editing and change the setting in the "Setting" tab, then navigate to the Blackline tab. Edited by spongebob - 10 April 2019 at 4:23pm |
jacethebase
Yeah, I get that. From memory the settings for the BSS Omnidrives are on the website. You download a spreadsheet type file. |
