Omnitronic BX-1550 / 15" w/ 2x circular ports |
teeth
Young Croc Joined: 05 July 2021 Status: Offline Points: 566 |
Posted: 17 December 2021 at 6:36pm |
hi there peeps, i've got a pair of cabinets that are apparently duplicates of Omnitronic BX-1550. the originals look like awful cheap things, but the owner was apparently attached to them enough to want to start work on a pair made from nice ply. they are really quite well made and my friend is finishing them off to a good standard. just wondering if anyone is aware of a similar design so i can check a few details regarding baffles, bracing, port length, etc i assume the cabinet dimensions are true to the original design, maybe that's all the original constructor checked for. they've put the top hat mount in the wrong side too :p would value any opinions and thoughts, i'm also after driver suggestions for these - if you have any, i'm all ears.
Edited by teeth - 18 December 2021 at 4:46pm |
Contour
Young Croc Joined: 03 March 2004 Status: Offline Points: 624 |
To select driver, you need cabinet netto volume and reflex port dimensions. Download winisd (free) so see what driver works.
teeth
thanks contour, plugged in some dimensions and had a play. great fun. now wondering if these could become kick bins...? they don't go very low.
