  New Posts New Posts RSS Feed - + & - on 6x9's???????help!!!!!!!
Noyzmunky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Noyzmunky Quote  Post ReplyReply Direct Link To This Post Topic: + & - on 6x9's???????help!!!!!!!
    Posted: 14 November 2006 at 8:42am
just fitting my 6x9's and they have two little slides for the signal input.
one is bigger than the other by quite a lot.
they have no mark to distiguish pos and neg so i hope this is a ''size shows which is which'' thing that i dont know about.
is the small one positive as a mate has said or the other way round???????
please, a little help as im fitting tonight....
cheers
my name is Inigo Montoya...you killed my father, prepare to die!.
adambomb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote adambomb Quote  Post ReplyReply Direct Link To This Post Posted: 14 November 2006 at 9:25am
9v battery.. posative terminal on positive speaker terminal will make the cone move forward.
Jay Lawless View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jay Lawless Quote  Post ReplyReply Direct Link To This Post Posted: 14 November 2006 at 4:57pm
yep!
the size thing is meant for little clips to fit tight on instead of raw wire. it's the right idea... but they leave out the markings as to what the polarities. generaly what i've found is that the bigger connection is always positive,but then again still make sure with a 9v battery, as long as it pops forward then you've got it.
Background: Automotive, Live and Home Custom Design. mid/high level based design and feild experience. Bass specialist
dj_jbl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dj_jbl Quote  Post ReplyReply Direct Link To This Post Posted: 22 February 2007 at 2:45am
big = +
