Outdoor Speaker recommendation? |
Shortrope
Posted: 19 April 2018 at 7:11pm |
Hey SP Hive mind...
I'm looking for a recommendation for nice a sounding active outdoor Speaker. They're going on a small roof terrace and will be wall mounted outside 365/24/7 slightly under cover out of direct Rain. Ta very much. |
imageoven
Old Croc Joined: 28 March 2007 Location: Scotland Status: Offline Points: 2186 |
Does it really have to be active?
Even with a bit of cover you're not going to want an IEC power cable going in the back of it with rain blowing around and that' going to limit your options significantly. IP rated passive speakers gives you lots of options and even un-rated passive speakers are not going to carry the risk of 240v outside.
partya
Registered User Joined: 06 September 2013 Location: New Zealand Status: Offline Points: 105 |
Where's your source coming from? Passive would also be better if you're getting your signal from a fair distance away.
You need pretty good shelter to run active outside (from expensive experience....).
Shortrope
Sh*t yes you’re right...I hadn’t really thought that through properly.
It’s a space issue really. There is a small sound system inside with 4 Channel Amp but I’d struggle to find space for another rack mount Amp for the outside Speakers. I could possibly use a small Hifi Amp, it’s only a small outdoor space. Ok...Passive IP rated Speaker recommendations please.
bassdesigner
Registered User Joined: 17 July 2016 Location: Lancashire Status: Offline Points: 228 |
Apart mask 6
4AC
Young Croc Joined: 18 September 2010 Location: Netherlands Status: Offline Points: 521 |
Maybe you should look at a Lab.Gruppen Lucia amplifier, very small and thus easy to find a space for. You can just put them on top of a shelve, mount them on a wall, or even mount them on a pole with a bracket. It has very acceptable sound quality and a built-in DSP, allowing to tweak the sound to your taste, or with presets for Tannoy and Turbosound speakers. It also has some kind of loudness function which adapts to the volume level, can be usefull in some applications (to prevent the common thin sound on low levels). Not the most affordable option though, ofcourse you also pay for the nametag on the front.
Tannoy DVS is IP64 rated and the AMS range is IP65 rated. AMS range is stupidly expensive but uses the same tannoy dual concentric as they have in some hifi speakers. Based on your info, I think even IP54 might already be sufficient, so maybe a cheaper alternative is the best option for you. If it has to be dirt cheap, Apart Audio has plenty of options I believe.
uǝɿɿɐʌǝ6ɯo sı ʇsʞǝʇ ǝzǝp
Shortrope
excellent thanks.
markie
Old Croc Joined: 31 October 2005 Location: Sunny Liskeard. Status: Offline Points: 4570 |
I have some Tannoy i6AW (all weather), which I bought as a job lot. They are unused but don't have the brackets. Any interest?
Shortrope
Yes Markie....I'll message you. Ta
dylan-penguinmedia
Old Croc Joined: 14 April 2011 Location: Brighton Status: Offline Points: 4575 |
outdoor actives = One Systems
(Or passives to be fair!) Cruise ship proof. Or Martin CDD-WR, or Apart.
