  New Posts New Posts RSS Feed - Outline Minibass, similar to HD15, questions
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 09 November 2014 at 9:26pm
http://nordiskmusik.se/Global/Pdf/Outline_Minibass_Stackbass.pdf
Should contain all you need to know, surely?
DjLeco View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DjLeco Quote  Post ReplyReply Direct Link To This Post Posted: 10 November 2014 at 7:36pm
Originally posted by cookie-dj cookie-dj wrote:
if your asking for peoples knowledgable opinions, have the decency to try out their suggestions seeing as they took the time to reply.
Just cut higher as they might play that frequency better than your 'full range' speaker
As I said, I don't want to play it above 120 Hz, is MORE THAN ENOUGH spl there.
I was asking about minimimum freq for cut off, type of filter BW or L-R, and slope db/oct.
Also for an known good bass shelving point.
Thank you.
They give there freq response, not optimal crossover points, bass shelving, etc.
Regarding those specs I decided to use BW filter with 30db/oct slope at 53Hz for low cut, and BW filter with 24db/oct at 120Hz fot high cut.
Any other opinions are welcomed, for low cut and bass shelving too.
Edited by DjLeco - 10 November 2014 at 7:37pm
bass*en*mass View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote bass*en*mass Quote  Post ReplyReply Direct Link To This Post Posted: 10 November 2014 at 9:06pm
depends a lot on your total volume/SPL required imo.
driver seems robust enough to take a beating. 500w p driver, hpf 18db bw 40-45hz, some eq to get desired response for the location, style played, upper x over to match your tops and prefered sound.. many people cut their bins way too high to get a smooth rolloff which imo forms the characteristics of bass sounds.
(for example 40hz dont need to be loud sometimes, hearing a 50hz bass rolloff naturaly down to 40hz sounds better than the same impulse beeing cut sharply above..)
Post Options Post Options   Thanks (0) Thanks(0)   Quote DjLeco Quote  Post ReplyReply Direct Link To This Post Posted: 10 November 2014 at 10:20pm
I'm afraid to cut lower than 53Hz, afraid of overexcursion of the driver...
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 11 November 2014 at 3:49pm
I would argue that the frequency response graph indicates pretty well where to put the crossover points.
