outline t6.5 /powersoft digam7000 service manual |
Page 123 7> |
noobsound ![]() Registered User ![]() Joined: 28 March 2008 Location: Romania Status: Offline Points: 67 |
![]() ![]() ![]() ![]() ![]() Posted: 05 October 2009 at 10:50am |
Hello. I am obout to buy a outline t6.5 amp ,basicaly a powersoft digam 7000 amp. I need a service manual or some schematics of the amp especialy of the power suply module. All fuses are ok but the amp is dead.
DjLeco ![]() Young Croc ![]() Joined: 21 April 2009 Location: Bucharest Status: Offline Points: 808 |
I tried to fix it, but without schematics, I can't do anything.
The amp is very dirty inside, I checked all fuses, are OK, also Mosfets, and diodes from powersupply part of SMPS and PFC, are OK...
After bridge rectifier I have 310 volts, it looks the command part of smps , doesn't work.
axeman91 ![]() Registered User ![]() Joined: 24 May 2007 Status: Offline Points: 249 |
I think the schematics are in the back of the manual for the digam 7000 are they not?
Basil ![]() Registered User ![]() Joined: 05 July 2009 Location: Lemberg Status: Offline Points: 18 |
Write the address and I will send the scheme
Thx verry much Basil my adress is: noobsound@yahoo.com
CelsoSC ![]() New Member ![]() Joined: 10 December 2007 Location: Portugal Status: Offline Points: 4 |
Hello,
Switch on and see if you have +18V at your mainswitch and GND. If not, double check the 100mA fuse and the small transformer near the fan. See also if you have +15V at the 7815 Regulator. Had some troubles with the standby supply. Kind regards |
miguelplus ![]() New Member ![]() ![]() Joined: 21 October 2009 Location: peru Status: Offline Points: 1 |
fredos666 ![]() Registered User ![]() Joined: 11 October 2008 Status: Offline Points: 205 |
Me too please...
alabpro ![]() Registered User ![]() Joined: 25 August 2006 Location: Thailand Status: Offline Points: 33 |
Hello... Me too please... For powersoft digam7000 service manual a_pracha@hotmail.com |
All interested persons can take the scheme noobsound@yahoo.com
dannyavila ![]() Registered User ![]() ![]() Joined: 08 March 2009 Location: Venezuela Status: Offline Points: 97 |
Hello Noob...
I've repaired almost a dozen of this power amps that fractured the cooper trace closer to the Logic Circuit transformer's contacts, which has nothing to keep it tighten to the PS board but its own contact legs. Remove it and you'll probably find immediately the cracked cooper trace below its footprint.
Cheers!
Danny Avila.
Tech Service Manager Inaudio Servicios Integrales. |
I.m on charge to rapair it, can U put some pictures of that zone?
The amp is purely dead!
Page 123 7> |
