P. Audio SD 18, better for 186 or 1850? |
Post Reply | Page 12> |
streetsounds
Registered User Joined: 12 July 2008 Location: Santa Rita Status: Offline Points: 301 |
Posted: 21 August 2008 at 11:06am |
Any comment on which box SD 18 will perform better, will this driver fits easily with 1850? Im planning to built 4 cabs using Paudio SD 18 but still confused which one to build, 186 or 1850. |
Bass matters...
Dub Defector
Registered User Joined: 08 January 2008 Location: Devon, UK Status: Offline Points: 801 |
we run sd18s in ours and they sound great.. a more rounded sound than the pd1850s IMO. The box had to be modified 'very' slightly if i remember rightly to get the driver in but other than that all good.
Though for your money i would pick up the V18 1000s as a far better driver for the 1850 horn. Edited by Dub Defector - 21 August 2008 at 11:18am |
streetsounds
did they also go lower or heavier than the pd1850? it might so coz it has a higher qts than pd1850. have you tried it with 186? Yah V18 1000 its gud, as many say but its not easily available here in my place. SD 18 you can get it anywhere. Are they of the same price?
Bass matters...
Deadbeat
Old Croc Joined: 12 March 2008 Location: Singularity Status: Offline Points: 3167 |
SD18 will work in either horn - Rog says it's just a matter of fitting - 1850 horn for larger stacks, 186 for smaller.
I think the V18-1000 might suffer from the same problem as the 1850 driver would in the 186 - listening fatigue, though I may be wrong. |
Away on extended leave.
streetsounds
yes deadbeat, i got already two 1850 with 186 chamber (i made a mess, i accidentally mixed them actually), i wanted to build 4 more 3 per side or stack of 6 would do for me for now and most likely to use sd 18 but im still confused which one 5to built 186 or 1850. Maybe ill just put another piece of plywood inside my two cabs to make it an 1850..idont know.
Bass matters...
Deadbeat
I think you should experiment with securing the piece temporarily, and decide whether you like the sound. Remember to do this with the other cab for a relatively fair comparison, though expect more lower end from an 1850 in a stack of 4 or more.
streetsounds
yah i think ineed to do that, ill let you how does it sounds, after putting temp piece on 1 of my existing cabs. AT moment they already sounds good but i need to replace them drivers, my amp and cabs are still needing for some more volume on the dancefloor
still asking for
Bass matters...
DJDNA
Registered User Joined: 22 February 2005 Location: Romania Status: Offline Points: 23 |
PAudio SD18EL is better than SD18.
H...
Young Croc Joined: 21 July 2008 Location: UK Status: Offline Points: 1164 |
not better - different!
DJDNA
Better for 1850.
mykey
readwhat Rog has said here, suitable drivers: |
Mircea Bartic
Old Croc Joined: 18 February 2005 Location: Romania Status: Offline Points: 2582 |
we tested the sd18EL in the 1850 some time ago.
performance is great. |
