PA sub baffle thickness |
Augusts
Registered User Joined: 07 January 2017 Status: Offline Points: 180 |
Posted: 18 October 2020 at 7:30pm |
Hi
I have been looking on a lot of PA sub designs and noticed that the driver mounting baffle thickness is usually the same as the rest of the material. If the driver is sitting maximally close to all walls surrounding the driver, does the baffle thickness matter? Like so: |
VECTORDJ
Young Croc Joined: 11 June 2006 Location: United States Status: Offline Points: 515 |
The thicker the better. 2 or 3 layers of 3/4 inch birch ply all round would make great speaker cabs.....oh the weight and cost.....oh My back.....
Augusts
Yes, that's what I was thinking that it would not be practical but would it matter if the baffle in this case was 2x the thickness?
snowflake
when the driver is that close to the walls it's not going anywhere. the basket assembly is going to be extremely stiff too and that's bolted to the baffle. plus the huge inertia of the magnet compared to the cone. not an issue at low frequencies.
if you want to put more wood in the box brace the larger panels. |
Augusts
Thank you , thats what I wanted to hear :)
I am planning to brace the larger panels. It is a transmission line for a 21" sub, 26Hz -10db
fat_brstd
Old Croc Joined: 23 August 2008 Location: Melbourne, OZ Status: Offline Points: 2126 |
Find a lot of double thickness baffles in scoop builds.
Melbournes Rootical Warrior Roots - Dub - Steppers facebook page |
Sinai Sound
Young Croc Joined: 09 November 2009 Location: Sheffield Status: Offline Points: 631 |
My scoops have a double thick 18mm baffle I'd like to think it helps
