Pad Thai Hifi Build Pictures |
Page <12 |
| Author | ||
jossdude
Joined: 16 September 2009 Location: Newcastle Status: Offline Points: 133 |
Posted: 16 November 2010 at 6:18pm |
Thanks everyone, we have enjoyed building them alot. Still cant wait to hear them. Managed to get 3 of the tops finished, so we are getting closer and closer.
Got the wood cut here, http://www.theworkhaus.co.uk/ , but luckily my Mum works there so we paid bugger all. Still ended up using 18 sheets in total so even in material ended up being a decent amount. Might be worth asking them, especially as you are in Leeds and so are they. Something that we would do different if we were going to get stuff CNC rebated again would be to have one side with a 18mm slot then have the other side with maybe a 19mm slot to allow for easier location. I dont know if it was our inexperienced woodworking skills or what but we had a bit of trouble on some of them getting the second half to line up. Anyone done this before? First time have worked with Birch ply and it is nice. It seems considerably lighter than MDF which can only be a bonus. JDCutta was right, they are Pflys hybrid horns, posted the build of them a while ago on here. Depending on if they can keep up or not will be the deciding factor if we keep them or not. What ever happens we will have them for a while tho until we have saved abit more money.
AJordan
Posted: 16 November 2010 at 6:34pm |
Nice work. When getting pannels CNCd, do you need to cut them to the exact size first or can/is that done as part of the CNC process?
pfly
Joined: 25 October 2007 Location: Helsinki, Fin Status: Offline Points: 2827 |
Posted: 16 November 2010 at 6:36pm |
Well, 4x PD12SB30 vs. 6x V18-1000, all horn loaded in the frequency range they are being used in this configuration...
TONY.A.S.S.
Joined: 21 February 2007 Location: United Kingdom Status: Offline Points: 6867 |
Posted: 16 November 2010 at 8:13pm |
Edited by TONY.A.S.S. - 16 November 2010 at 8:14pm |
jossdude
Posted: 16 November 2010 at 9:03pm |
That makes sense, we cut our rebates to exactly 18mm but sounds like we were lucky and as they fitted in perfectly. We just needed to slightly chisel out 2 sections but the rest of the pieces located perfectly together. We did have one of us stood on the side though when we were screwing and glueing.
For CNC cutting you can get all of it done at once. We even got our speakon connector areas and the holes for the wheels CNC cut at the same time. Just need someone to know what they are doing with CAD really, or be willing to learn.
biotec
Joined: 07 June 2004 Location: United Kingdom Status: Offline Points: 2932 |
Posted: 17 November 2010 at 9:23am |
I use a an 18.5mm router cutter when doing rebates. I find with the width of the glue film it a royal PITA to get 18mm panels into an 18mm slot. I'm sure tony's 19mm is also fine.
login4
Joined: 03 April 2006 Location: Wales Status: Offline Points: 1552 |
Posted: 18 November 2010 at 6:51pm |
looks really nice,
so did the hybrid horns not drop that deep then in the end? is that why you built the scoops? the reason i ask is im quite interested in the hybrids |
CELTIC SUBSONIC SOUND SYSTEMS
pfly
Posted: 18 November 2010 at 7:08pm |
They definitely do drop to around 45hz, but they are still 400W rms 12" jobbies. No one should expect HOG class performance down there from them
jossdude
Posted: 18 November 2010 at 8:30pm |
Exactly what Pfly said, I am really really happy with them. But we just wanted to go bigger and 4 x 12" drivers compared to 6 x 18" is quite a difference. They still work brilliantly on there own and the system will probably end up getting used most often without the hogs for now anyway.
Page <12 |
