  New Posts New Posts RSS Feed - Paraflex in reggae
Paraflex in reggae
BigSoundNorthWest View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BigSoundNorthWest Quote  Post ReplyReply Direct Link To This Post Topic: Paraflex in reggae
    Posted: 04 September 2022 at 10:25am
Been hearing some good things about paraflex bins and tops.
Who else, apart from Sinai and Volcano, are running paraflex, in dub n reggae. I heard Volcano at NHC.
Edited by BigSoundNorthWest - 07 September 2022 at 11:10am
JamesH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JamesH Quote  Post ReplyReply Direct Link To This Post Posted: 08 September 2022 at 7:49am
have u checked the facebook page?
vibes92 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vibes92 Quote  Post ReplyReply Direct Link To This Post Posted: 23 November 2022 at 3:25pm
concrete lion
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 23 November 2022 at 5:02pm
So forgetting about sims and plots, how does 1x21" paraflex, compare with a decent 21" Full Scoop,   32hz - 100hz !?
Edited by levyte357- - 23 November 2022 at 5:03pm
bob4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bob4 Quote  Post ReplyReply Direct Link To This Post Posted: 23 November 2022 at 6:58pm
Wasn't there a post here on speakerplans from  a person that replaced  18" scoops with altcon 15" paraflex loaded with 15ds115 (yes, those exist, that's not a typo!!). He reported very good initial results.
Iirc it was user "noud", in a thread about a top build.
EDIT: found it!
Edit 2: scoop was apparently fane 18xb loaded.....
Edited by bob4 - 23 November 2022 at 7:13pm
bob4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bob4 Quote  Post ReplyReply Direct Link To This Post Posted: 23 November 2022 at 7:14pm
Originally posted by Noud Noud wrote:
Goodevening Guys,
I Started building some new subwoofers to replace my scoops.
so I looked at a lot of different kind of subs like:
-th18 xoc1
-cyclops
-tham18
-tham 15
-Cubo sub
-21 br
and finally a paraflex Altcon 15
I wanted to be smaller go just as low or lower en just as loud. (if possibleBig smile)
so I started reading and reading and a bit more of reading.
until I finally decided to go with the Paraflex Alton 15.
the Hornresp sim so a similar output and range as the scoop.
so I de build begon and there are some result in the pictures.
Keep in mind the scoop is about 590Liters and the Alton 15 only 312Liters
Green=scoop 18XB
Purple=Altcon 15ds115
HPF=34hz
LPF=100hz
luton_soundman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote luton_soundman Quote  Post ReplyReply Direct Link To This Post Posted: 24 November 2022 at 2:58am
Not even comparable to a shutter ply 18" sb with minimal bracing. I wouldnt even use paraflex for pa let alone reggae. Definatly a design that shouldnt have left the work shop imo.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BigSoundNorthWest Quote  Post ReplyReply Direct Link To This Post Posted: 24 November 2022 at 2:22pm
If I was going to move away from scoop based bass, I think I'd rather go bandpass style , kinda like what Kutty is putting out, rather than paraflex...
Edited by BigSoundNorthWest - 24 November 2022 at 2:22pm
Sinai Sound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sinai Sound Quote  Post ReplyReply Direct Link To This Post Posted: 24 November 2022 at 9:17pm
If you want to come over the Pennines with your boxes, you're welcome to A/B them against mine
Got a warehouse space with 3 phase power where we can run it as loud as you want.
This offer goes for anyone.
cookie-dj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cookie-dj Quote  Post ReplyReply Direct Link To This Post Posted: 25 November 2022 at 3:04pm
I think I will build 18/21 double bandpass manifold boxes from the 18sound enclosure designs page - if I get bored of my mini scoops. I like their drivers too!
You can't polish a turd!
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 25 November 2022 at 3:43pm
In my universe,  a 1x21 paraflex, would need to "Thanos"  a 1x21 Full Scoop, 32hz-90hz, to justify it's existence.
goodgroove1960 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote goodgroove1960 Quote  Post ReplyReply Direct Link To This Post Posted: 25 November 2022 at 8:02pm
I have heard a 21" Paraflex a/b with 21" hog  , 21" flh and 21" tapped horn all run on same amp , just a listening test ,it was agreed by the 6 people present the paraflex was very impressive over the other cabs , will say it was noted it had a 4r driver but even so in all aspects it suprised us
