  New Posts New Posts RSS Feed - Parallel outputs..meh?
odc04r View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote odc04r Quote  Post ReplyReply Direct Link To This Post Posted: 21 June 2007 at 11:33pm
Yes sorry, I meant stick the parallel transistors of each channel in series with each other, so they all end up in parallel.
Bad wording maybe, makes sense to me :)
wasup View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wasup Quote  Post ReplyReply Direct Link To This Post Posted: 22 June 2007 at 1:53pm
Can you put a xover between two amps that have been switched to parallel?
Lets say make the signal going to the second amp more sub than bass!!
thnx
gingerbiscuit69 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gingerbiscuit69 Quote  Post ReplyReply Direct Link To This Post Posted: 28 June 2007 at 11:22am
adam - they are just connected inputs, ie: channelA feeds both channels (but they stay independant of each other in gain ect...).
used this at your partys for the bass end when i wired up.
adambomb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote adambomb Quote  Post ReplyReply Direct Link To This Post Posted: 28 June 2007 at 11:29am
that's what I was hoping.... but as the manual mentioned @ 2ohm I thought I would check (as I know not all amps are the same when it comes ot parallel).
