  New Posts New Posts RSS Feed - passive cross over basic question
dj jammin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dj jammin Quote  Post ReplyReply Direct Link To This Post Topic: passive cross over basic question
    Posted: 01 January 2019 at 6:54pm
If you take an off the shelf 2-way passive cross-over (7KHz in this case) and just connect the high output (to a bullet tweeter in this case), does it act as a 7KHz hpf OR does having no driver connected to the 'low' output affect the cross-over point etc?
Reverence Sound system
www.mixcloud.com/B1_Jams/
mini-mad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 01 January 2019 at 8:28pm
A two way is NORMALLY just a low pass on one channel and high on the other so to speak. So no, you don't need a load on the other bass side
odc04r View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote odc04r Quote  Post ReplyReply Direct Link To This Post Posted: 02 January 2019 at 9:05am
Short answer, no it won't be a problem. The two channels of the crossover operate independently from each other if it is a conventional design (which it almost certainly is). Crack on.
ceharden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 03 January 2019 at 12:13am
It won't affect the high end BUT it's generally not a good idea to just connect an LC network (the unused LF side) to an amplifier as without a speaker connected (resistive load) it could provide a very odd load at certain frequencies.
To be safe, I'd lift one end of the inductor on the unused low pass side of the crossover.
Post Options Post Options   Thanks (0) Thanks(0)   Quote odc04r Quote  Post ReplyReply Direct Link To This Post Posted: 03 January 2019 at 9:12am
I was considering that, depends whether it is RC/LC/RC etc also. I expect it would be ok though even if you left it in, by the time the network is going solo (so to speak) the reactance should be quite high. Although ofc amps don't like capacitative loads much so ymmv. If you are happoy to do so then it probably would be a good idea to disconnect the LF side just to be sure.
markie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote markie Quote  Post ReplyReply Direct Link To This Post Posted: 03 January 2019 at 10:05am
As you are proposing to use an off the shelf unit, why not build your own. If you build high pass filters you will only be buying 1/2 the components so it will give you the opportunity to use better quality components for the same, or even less money.
There are calculators online and they are quite simple to make.
Edited by markie - 03 January 2019 at 10:05am
This page was generated in 0.082 seconds.
