Passive crossover advice |
Page 12> |
Jack1991 ![]() Registered User ![]() Joined: 05 February 2020 Status: Offline Points: 280 |
![]() ![]() ![]() ![]() ![]() Posted: 12 February 2020 at 1:29pm |
Hi i wondered where people get there passive crossovers from? Im UK based. They seem quite expensive the pre-built ones and there doesnt seem to be much choice online. I saw some people make them thereself but that is far beyond my knowledge right now to do that. Surely most buy pre-built anyway id imagine??
Its a Mid-Top speaker im going to build. 3.5k crossover point 8ohm 8" mid driver with a cd horn tweeter Any advice or pointers would be great thanks.
Edited by Jack1991 - 12 February 2020 at 2:08pm |
dlyxover ![]() Young Croc ![]() Joined: 14 June 2007 Location: Liverpool Status: Offline Points: 1475 |
if your up for the challenge build your own
In the Truth there is no news, and in the News there is no truth
I would love to, but i would need a detailed, simplified, step by step process to follow. Like a "crossovers for dummies" guide or something. And i imagine it would end up costing more than buying a pre built one once id bought all the tools/bits needed Edited by Jack1991 - 12 February 2020 at 3:09pm |
Chris Grimshaw ![]() Registered User ![]() Joined: 10 September 2018 Location: Sheffield Status: Offline Points: 280 |
Some of the tools are pretty cheap. REW and XSim do the job just fine. However, you'll also need a measurement setup and the knowledge on how to use it effectively. IMO, pre-built crossovers are a waste of time unless they're intended for the exact speaker you're building. Different speakers have different impedance and frequency curves, and therefore each needs to be treated individually if you want best results. If you're near Sheffield, gimme a shout. Chris
Quality sound from Sheffield
www.grimshawaudio.com |
Oh right ok cool thanks for the info. It definitely does sound far beyond my knowledge then.
Would you say the difference of using pre built and a custom made one is night and day? Or is it something for a first time speaker builder it would be just fine. Im not looking to build the worlds best speaker but obviously i dont want it to sound crap either. Also thanks appreciate the offer but im down in bristol.
Edited by Jack1991 - 12 February 2020 at 4:25pm |
Another thing i wondered is this
If i have 2 identical speakers (mid 8ohm, tweeter 8ohm, crossover 8ohm) If i ran 2 of the same speakers in parrallel to get a 4 ohm load. Will that affect the 8ohm crossover. Or will it all be fine? Thanks
A generic crossover will never sound as good as something purpose-built for the drivers you've chosen. The "not sound as good" could be anything from a big peak or dip in the response, and/or inadequate tweeter protection resulting in premature driver death.
Passive crossovers react to impedance changes, and it's not always predictable. Active crossovers are easier in a lot of ways, and make sense for medium-to-high-power PA systems. Chris
ceharden ![]() The 10,000 Points Club ![]() ![]() Joined: 05 June 2005 Location: Southampton Status: Offline Points: 11575 |
I'm working on a passive crossover design at the moment. Taking significantly longer than the time it took to build the actual cabinet!
Yep, sounds about right. I find XSim to work pretty well if your measurements are decent. Chris
Not used XSim before, previously done it more by trial and error plus a couple of spreadsheets which do some of what XSim can. Since a few people have mentioned it I thought I'd give it a go, loaded my impedance plots in and it's really helped. Still trial and error to some extent but quite useful to check out what varying each component value will do before trying it in practice.
Finally got something I was happy with this afternoon.
Yeah, it won't tell you what to do, but it'll show you what happens when you do something. It gets easier with practice. If you get into the menus, it shows you component power dissipation, too, which is useful for speccing resistors etc. Chris
Page 12> |
