Passive crossover |
bassdesigner
Registered User Joined: 17 July 2016 Location: Lancashire Status: Offline Points: 228 |
Posted: 30 December 2017 at 2:38pm |
Is there anything off the shelf that I can buy to use in a single 12" Sun so that it feeds the sub low frequencies and then has had a high out to a small 8" top like something that is in the peavey pro sub so all 4 boxes can be run from one amp?
krazyneil
Young Croc Joined: 06 December 2007 Location: Bolton ,lancs Status: Offline Points: 1206 |
something like this
GOD TOLD ME TO DO IT !!!!!
bassdesigner
Yes exactly like that but hopefully cheaper! |
krazyneil
you could use a pair of these maybe
just fit them in the boxes out of sight
bassdesigner
Good shout! |
JonB67
I have a pair of plate amps from some peavey pro subs if you'd rather go active but do the same thing?
bassdesigner
How much are you after? |
mini-mad
But then you can control the power over the two different bands... yes it's less equipment to carry but your losing control over your boxes as a result.
Ok it might be ok for disco Dave stuff. But is there any reason you want to do it this way? |
bassdesigner
It's just to keep it as simple as possible, main priority is being able to chuck it in my boot, carry as little equipment as possible and will only be used for house parties small gatherings |
