P-Audio SN 15MB Dis-continued! |
Post Reply | Page <12 |
reessi
Registered User Joined: 18 August 2011 Status: Offline Points: 158 |
Thanks for your reply, I have compared the parameters and the P-Audio 15BM-300B 15" 300W would seam to be the closest match but the paramaters are not exactly the same, but I do not understand how to use the parameters to calculate if the box will work for the newer model? Do you think it will work ok without modificaton. I understand that there is an optimum air volume you want inside and the port length size is important! P-Audio SN 15MB 300w old model: Thiele-Small Parameters P-Audio 15BM-300B 15" 300W New model: Re.....................................................................................5.7 Many thanks - Simon. |
cravings
Old Croc Joined: 30 January 2007 Location: Ireland Status: Offline Points: 7439 |
winisd pro is the (free) software you want.
don't get hung up on the wattage.. it's not an important specification really. |
teeth
Young Croc Joined: 05 July 2021 Status: Offline Points: 561 |
where did you get to reesi?
i'd be interested in any recommendations of drivers for the X15 - the SN15MB is long long gone now, and p audio kit is hard to get hold of in the UK atm |
cravings
did you not get a driver?
i replaced some sn15mb in some xm15s with bms 15n620 for a while... they are good. think people also used to say eminence kappalite were also appropriate replacements |
teeth
i did get one aye but it's in germany :( also aware that if anything happens there's no way to recone it seems... i'll look in to the kappalite - thanks
Earplug
Oh no - did it get stuck there? What are you going to do? |
teeth
i got spooked bringing it back on the plane, figured airport security might not be kind about a large magnet... didn't want to risk losing it. hopefully a friend will be driving over before the year is out! thanks for sending it earplug :) in the mean time i guess i'll start poking about with drivers for the X15, good exploration time to be had perhaps. nice springy neos being first port of call
Earplug
Aaah ok - as long as you do find a use for it. It is a good driver. |
teeth
any opinion on the 18sound 15ND930 for this use, folks? |
