  New Posts New Posts RSS Feed - PD 1550 Reflex Box
PD 1550 Reflex Box
bujinkan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bujinkan Quote  Post ReplyReply Direct Link To This Post Topic: PD 1550 Reflex Box
    Posted: 04 June 2010 at 4:52am
I'm wanting a reflex box for a Pd1550 , to play from 80hz to about 200hz
when i model it in  win isd  (with one port) the best enclosure size seems bout 40 litres? But the recommended size (according to precision devices) is 80l to 200l????
I've double check all the parameters heapz of times...
any ideas anyone?
many thanks in advance!
bass*en*mass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bass*en*mass Quote  Post ReplyReply Direct Link To This Post Posted: 04 June 2010 at 4:57am
80-200l is stated for a real bass cab playing down to 40hz...
if you only need it to play from 80hz up then of course size can be reduced.
(you could even use a sealed cab to reach 80hz lowcut freq.)
This page was generated in 0.061 seconds.
