  New Posts New Posts RSS Feed - Pd 158
Pd 158
philip banyer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote philip banyer Quote  Post ReplyReply Direct Link To This Post Topic: Pd 158
    Posted: 16 May 2023 at 8:35pm
Hi im looking for some advice please. I have 8 pd 158s I would like to put them into double 15s cabinets total 4 cabnets. They would be crossed from 70hz or even a bit higher. For the high then crossed to a beyma cd10fe tweeter as I have a lot of these spare.
I release it's not perfect but most likely it could work somewhat.
   Could someone please recommend me some plans that could use.
Xoc1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Xoc1 Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2023 at 9:43pm
I think a single 15 to 1" might work as the PD158 has a reasonable HF response but, any 15 to 1" combo is likely to be a compromise with beaming from the 15".
Trying to get a pair of 15" drivers to crossover to a 1" is likely to be very messy.
Then I thought of Graham Audio who use slot loading to improve dispersion from larger drivers. Maybe something like that could work, if you are determined to make something with the drivers you have!
Edited by Xoc1 - 16 May 2023 at 9:45pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote philip banyer Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2023 at 9:07am
Thank you for your reply.
I had not thought much about the beaming problem.
Possibly joining 2 tweeters together with an y adaptor to a larger horn may help?
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2023 at 9:57am
When you really power the 15s, overall sound will be terrible.
PD158 is one of my fav 15" drivers, but they are not designed to xover into a tweeter..
Xoc1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Xoc1 Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2023 at 10:00am
Not What PD themselves say ?
But I have not used them personally
PD.158
SUB BASS DRIVER
  • Heavy-duty cast aluminium Chassis for increased rigidity
  • Double suspension system
  • Easy integration with 1″ or 2″ compression drivers
  • Effective transducer in a variety of versatile applications
  • Also suitable for 1×15″ or 2×15″ horn loaded/bandpass sub bass designs
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2023 at 10:41am
PD.158
SUB BASS DRIVER
OP say's he wants to crossover into a Tweeter !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2023 at 10:43am
PD.158
SUB BASS DRIVER
Xoc1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Xoc1 Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2023 at 1:10pm
The beyma cd10fe
Is definitely a 1" compression Driver.
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2023 at 1:50pm
The beyma cd10fe
Why did he say "Tweeter then" !?
Most cabs that have 15" and 1", have gap in freq between them, as most 15s dojn't sound too good over 1khz, and most 1" won't sound that great or last that long, coming in at 1khz.
Now 12" drivers run upto 2.4khz, and then crossed into 1",  different kettle of fish.
snowflake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2023 at 2:28pm
if a 15" is beaming at 1kHz then a 12" will be beaming at 1.25kHz. 12" to 1.4" means better vocals with a little less top end response.
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2023 at 2:40pm
I've always found it quite easy to get smooth sound, from 2x12 reflexs upto 2khz, with 1"/1.4"/2" above.
if not using bullets above 2" comps, then running 12s upto approx 2.4khz, allows Beyma CP750TI/B&C De85 2" Comps, to give just enough sparkle around 15khz.
With shaping eq, obviously.
