PD.186 / 186.2 |
Page <12345 7> |
| Author | |||
KidCreole
Joined: 06 November 2013 Location: London (East) Status: Offline Points: 3580 |
Posted: 06 May 2014 at 10:52am |
PauliePaul
Joined: 14 August 2009 Location: Birmingham Status: Offline Points: 1485 |
Posted: 06 May 2014 at 11:03am |
Make sure they take into consideration how PD measure first though aye? Power test for two hours / measure / power test for a further two hours / measure - then take a mean value of the two sets of figures. It gives figures that reflect how the driver will perform after it's loosened up a bit.
Pasi
Joined: 25 April 2010 Location: Knutsford Status: Offline Points: 2685 |
Posted: 06 May 2014 at 12:42pm |
Why not just use the last set of figures as that would be the closest one to real life?
PauliePaul
Posted: 06 May 2014 at 12:45pm |
Honestly not sure!!
ras i
Joined: 04 July 2010 Location: JA Status: Offline Points: 341 |
Posted: 06 May 2014 at 1:27pm |
Not sure what the deal is with PD at the moment, but what I know for sure is the new 186 is not the same as the old ones. I tested them myself and the new ones perform more like the fane sov 18 than the old 186. Whether or not the parameters where incorrect on the old ones, they certainly are different to the new ones which IMO is not good.
I was also present last week when the 1852s in question was tested in the lev scoops and the new chassis 1852 didn't sound as smooth as the proto ones used when the lev scoops where played in Golden Palace. Not only did they not sound as smooth they seemed to bottom out much ealier. And yes they did all have gaskets in place. |
Sun Sun Sun
Pasi
Posted: 06 May 2014 at 1:45pm |
Comparing 2 things weeks apart and saying definite conclusions based on that? Yep yep...
PauliePaul
Posted: 06 May 2014 at 1:50pm |
Well, in that case, i know who you are... finally. And, one driver did have a gasket because I fitted it retrospectively and the other didn't so a comparison test could be done.
ras i
Posted: 06 May 2014 at 2:44pm |
Didn't know my Identity was a secret The new chassis 1852 that was tested did have gasket fitted saw that personally and the cab also had gasket fitted around the cutout. |
Sun Sun Sun
Tweeter_Box
Joined: 23 June 2012 Location: London Status: Offline Points: 859 |
Posted: 06 May 2014 at 2:52pm |
Dunno bout all that, but ive personally done a side by side test with old chassis and new... |
MarjanM
Joined: 10 February 2005 Location: Macedonia Status: Offline Points: 7845 |
Posted: 06 May 2014 at 4:20pm |
I am not sure the lack of gasket can make any significant difference. If the paint is thick enough and drivers are tightened properly you do not need a gasket.
fourway hornloaded
Joined: 16 March 2014 Location: Hamburg Status: Offline Points: 60 |
Posted: 06 May 2014 at 5:08pm |
There you go, PD1850, PD1851 and PD1851.2.
These guys at prodance do quite a lot of measurements. http://www.prodance.cz/files/dl/1/721/PD_1850.pdf http://www.prodance.cz/files/dl/8/15604/PD_1851_2.pdf http://www.prodance.cz/files/dl/1/722/TS_PD1851.pdf http://www.prodance.cz/files/dl/1/1958/pd.1851_2011_.pdf |
levyte357-
Joined: 27 July 2012 Location: UK, South East Status: Offline Points: 8517 |
Posted: 06 May 2014 at 5:22pm |
Some real ropey figures there.
Think he may have measurements for '50 & '50/2 reversed. Edited by levyte357- - 06 May 2014 at 5:32pm |
Page <12345 7> |
