  New Posts New Posts RSS Feed - PD.186 / 186.2
PD.186 / 186.2
 Post Reply Post Reply Page  <1 4567>
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2014 at 11:40am
Originally posted by JR.junior JR.junior wrote:
I knew this was inevitable at the moment Eminence got their hands on PD.
Too bad. Another legend goes to the history.
Broken Heart
I'm finding RCF have plenty of drivers, that could quite possibly be used, where old PD186 might have been spec'd. LOL
Testing commences next week.
fourway hornloaded View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fourway hornloaded Quote  Post ReplyReply Direct Link To This Post Posted: 08 June 2014 at 12:37pm
I got a PD186/2. It's indeed very similar to the old one, except it looks better. I would not be surprised if it performs just as good.
The only thing is - right at the moment I wanted to put it into a box, I discovered with great surprise that it doesn't have the proper hole pattern. I can't use it.
I did design my bins for PD186 but because I wanted to have the option to test other drivers, I used the normal hole pattern. Which worked out because the 18sound driver does a very similar job in that box. (thanks for the reactions on here - 'hitting sound' problem turned out to be lack of gasket).
You know PD186 used to have both the PD proprietary hole pattern and the normal one, that every other manufacture uses? That last one is not there anymore.
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 08 June 2014 at 12:44pm
Maybe PD are awaiting new stock of M6 holes for interior bolt pattern, and currently just sending drivers out, without them.
Edited by levyte357- - 08 June 2014 at 12:46pm
hmaudio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hmaudio Quote  Post ReplyReply Direct Link To This Post Posted: 08 June 2014 at 2:15pm
recently built some cabs using a mk1 chassis for bolt pattern then fitted mk2 chassis and had no problems
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 08 June 2014 at 3:17pm
he's saying the 8 hidden holes are no longer there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hmaudio Quote  Post ReplyReply Direct Link To This Post Posted: 08 June 2014 at 3:31pm
ahh i get you sorry i miss read.
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 08 June 2014 at 5:48pm
Which is is fantastic again, if you have 186 Horn, or other folded horn, tnutted for interior PD holes, and cab is almost impossible to re-tnut.
So I guess old version PD186 will also be going up in price, as well as old version PD1850.
BASSHORSE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BASSHORSE Quote  Post ReplyReply Direct Link To This Post Posted: 08 June 2014 at 6:07pm
good ive got 4 waitin for the price booom LOL
Adam_Iron_Horse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam_Iron_Horse Quote  Post ReplyReply Direct Link To This Post Posted: 08 June 2014 at 6:22pm
My pd 186/2 have both bolt patterns I believe...
Kryptonik Sound Kollective
www.facebook.com/kryptoniksoundkollective
GwanStefani View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GwanStefani Quote  Post ReplyReply Direct Link To This Post Posted: 28 April 2015 at 10:31pm
Does anyone know if there is a definitive way to tell between the original 186 and the 186/2 just by looking ?
PauliePaul View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PauliePaul Quote  Post ReplyReply Direct Link To This Post Posted: 28 April 2015 at 10:44pm
PD.186/2's have a rounded chassis flange and smoother lines, also the bottom plate on the motor has a chamfered edge. The badge will on the back will still say PD.186, but the sticker on the motor under the terminals will say PD.186/2. Also, any driver with a production date after say May 2013 will be a /2 model.
And finally, the PD.186/2 are 6mm deeper than the PD.186.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GwanStefani Quote  Post ReplyReply Direct Link To This Post Posted: 29 April 2015 at 11:31am
Thanks Paul, will need to take them out and measure up but I think our's may actually be the older model
