PD 186 4ohm or 8ohm? |
_banksy_ ![]() Registered User ![]() Joined: 18 January 2010 Location: Ireland Status: Offline Points: 31 |
![]() ![]() ![]() ![]() ![]() Posted: 24 January 2010 at 3:49pm |
As the title says, whats better to load the 186 with? a 4ohm or 8ohm pd186 speaker. This might seem like a silly question, but whats the difference?
cheers. will |
BreakBeat!
Naff_monk ![]() Young Croc ![]() Joined: 11 July 2009 Status: Offline Points: 500 |
Depends on how many you want to run and how you're planning to amp them. I would say that 8r is usually more common atm coz that means you can get 2 per channel at 4r (Ohms/number of speakers). If you're using it on 2r per channel, you will get more from your amp but the stability of running amps in this mode for bass is a bit of a controversial subject and could result in you cooking your amp
![]() Edited by Naff_monk - 26 January 2010 at 11:24am |
