Pd 615wg in Turbosound Floodlight |
Post Reply | Page <1234> |
bee
Old Croc Joined: 14 June 2011 Location: Middlesex Status: Offline Points: 4553 |
hi guys, sorry never kept track of this thread, I swopped them over 2 years ago, and there still going strong. I never done a full rta reading vs original. but to the ear they sounded tighter than the very warn old units. I done an a/b 2 boxes new 6" to 2 x old (left right stack) and the new sounded tighter, less loose to the older ones. The advice I got from Paul was it was a direct replacement... and the same as the original turbo unit.. this differs to what pd are now saying.....
rubjel
Registered User Joined: 08 January 2014 Status: Offline Points: 31 |
Hi Bee, thanks sharing. From your observations, I think it's safe to say that the 615WG is a good replacement for the LS6503, even if its not exactly the same.
Were the old units faulty when you say they were loose?
montarbo
New Member Joined: 06 September 2006 Location: Germany Status: Offline Points: 9 |
Meanwhile I tried the PD615WG/2 in my Floodlights by myself too.
The Information from PD is correct. The Cone is more shallow, so if you think about a sectional drawing, the distance between Phaseplug and Cone is increasing faster from the inside out of the cone. I also did some A/B testing to the old LS6503. It's some time ago but there was not much difference.
bee
Montarbo, this is correct re cone being more shallow, but is cone movment an issue, in one way yes, but another no. in the frequency range the 6" plays even at full power, the cone only moves about 1 to 2mm max, and this even at 2mm still clears the phase bung... I have a blown one (original hear) ill double check. The ones in said floors all worked, they were just well used, and sounded loose (in tone) no way near as tight as they should of sounded. I also swopped out the fane comps for the bms screw on ones. These actually sound better than the fanes.. I think this was the same mod done by formidable audio
bee
I should add I sold all 8 floods last year, and the current owners blew the 4 cabs we left as standard. (I had planned to upgrade the 6" and comps in these). the modded ones are still going strong. So the pd 6" has lasted many many gigs with no issues regarding cone rub...
rubjel
Excellent info, thanks! I also just recently swapped to the BMS 4540, a very nice upgrade over the EV DH3.
kedwardsleisure
Old Croc Joined: 20 January 2009 Location: Staffordshire Status: Offline Points: 4938 |
The last turbo I had with a duff mid, I offered up a 615 I had in stock, ouf of curiosity, and decided the cone was too close to the waveguide for my comfort. I'd have been happier fitting a small gasket to bring it back a few mm if one existed...and if it were my own cabinet rather than a clients. The old one got reconed instead.
Like Bee said, the cones hardly move in any case, but I made my decision! PS, had a Mackie SR1530 cab in last week with the closed=back mid replaced by an open backed eminence (not by me). To make it closed-back, it had an ice-cream tub glued to its rear. Sounded just the same as it's unmolested partner in a listening test! In fact, if anything, the mids were smoother, almost creamier.... Edited by kedwardsleisure - 15 August 2017 at 11:26pm |
North Staffordshire |
bee
lol... I shim would be a good idea, a standard washer should do it. for a tad extra clearance.
Hvedstrup
Registered User Joined: 30 October 2009 Status: Offline Points: 413 |
Can't see this as a option. The Floodlights phase plug bolts through the driver and the 605ND doesn't even have a hole in the dust cap and magnet for the threaded rod to go through.
Hvedstrup
Since the DH3 only plays from 8khz and up I find it hard to believe that one can tell a big difference. If you try muting all other passbands and only let the 1" play in the Floods it's obvious that they aren't really doing much. Maybe it's just my chosen gain structure that makes it like this. In a stack of 2x tsw-718 with floods on top I usually run +3db sub , lo-mid 0db, hi-mid -3db, hi -2db. |
Risc_Terilia
Young Croc Joined: 15 December 2007 Status: Offline Points: 689 |
Yeah talking generally, not for floods. Incidentally the "dust cap" on the 605Nd actually is a sort of small phase plug which does attach to the magnet.
rubjel
The difference is very obvious if you do it the other way, muting only the BMS, the sound is very dull. The BMS is an excellent driver, much smoother and nicer than the DH3.
