PD1550 in HD15 |
Post Reply | Page <123> |
JR.junior
Old Croc Joined: 14 December 2009 Location: Slovenija Status: Offline Points: 1789 |
PD154 is a beast! It has a huge magnet in a 15" range. The magnet is even bigger than at PD186 18" driver. Edited by JR.junior - 09 June 2010 at 11:10pm |
tv00
Old Croc Joined: 10 August 2009 Location: Denmark Status: Offline Points: 1886 |
strange, pd homepage says xmax 6,5mm:
http://forum.speakerplans.com/topic34629_post404540.html#404540 different from data sheet How many watts on the SPL? looks much louder than this rcf l15s800 & pd158 spl print, here the rcf seems to have a more flat response, rcf first: 158: http://img24.imagevenue.com/img.php?loc=loc1&image=26d_HD15_PD158.jpg or page 6 in "HD15 driver sims" |
JR.junior
6,5mm is from old datasheet (400watt). In 2005 PD updated all drivers (PD154 has now 500watt, better Xmax) and so all new PDF datasheets are corect http://www.precision-devices.com/asps/uploads/super/6.pdf .
PD154 and PD1550 uses the same cone and sorroundig. Displacement limit 22mm (peak-peak). The PD158 has smaller cone area. Edited by JR.junior - 10 June 2010 at 7:46am |
Meat
Old Croc Joined: 05 June 2009 Location: Manc Status: Offline Points: 1514 |
So 1550 and 154 simulate the same(ish) but do they sound the same?
Some people complain the 154 sounds 'brutal' or 'hard edged'. Is this less or more or the same with a 1550? SPL isn't the be all and end all. |
tweeter box
Old Croc Joined: 21 October 2007 Location: United Kingdom Status: Offline Points: 6784 |
I did alot of looking around and testing when i was deciding what to load my boxes with
1550 does have a slightly smaller magnet than the 154
larger x max than the 154 also
played a lil louder than the 154 and also clearer (whilst louder) on the 80hz and 220hz freq ranges
resale value on the 1550 is better than the 154
1550 can be used in other types of cabs also incase you do change your mind at a later date
no prizes for guessing what my boxes are loaded with
btw, my box is ever so slightly different to the HD15 but not alot in it to be fair
cravings
do you use old turbos tweeter? i think i remember you interested in some...
JR.junior
PD154 works awsome in horns.
tweeter box
yes mate, Turbosound TS215 copies, not alot of difference to the HD15 to be honest, internal dims are only a CM or two out, only diff i can see is that they have a 2 piece section instead of the curved section
they came loaded with PD154 but after testing i opted for the 1550 beasts
running a (2 x 15") box @ 4r of each side of a C Mark mr2650 amp n they love it, can play quite deep aswell if right processing is used Edited by tweeter box - 10 June 2010 at 12:11pm |
cravings
mine have pd154s in them (well the loaded ones do.. i have 4 singles and 2 doubles). they do bang hard. i use them over X1s. fane colossus 15b also sounded really nice in these.
cravings
no i don't.. i have 4 singles and 4 doubles..
LSS
Registered User Joined: 11 February 2010 Location: sheffield Status: Offline Points: 56 |
i have two hds with pd154 a hd215 with pd1550s its still got kick but i can run it down to50 55 just to get a bit more bass and i have two with fane xb i think these sound same as the 1550s but can get a warmer bass hope that helps
LIQUIDSTEELSESSIONs.co.uk
tv00
Thank you
Ths means that you think the xb sounds like the 1550 or even better? |
