  New Posts New Posts RSS Feed - pd1850 aes or rms
pd1850 aes or rms
 Post Reply Post Reply Page  <1 3456>
Timebomb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timebomb Quote  Post ReplyReply Direct Link To This Post Posted: 17 November 2009 at 1:40pm
Originally posted by Meat Meat wrote:
The reason why 1850s are seen to take more power is because most people use them in stacks of horns which increases efficiency a lot. Conservation of energy means that if you're emitting more energy as sound, you are also making less heat. AES and RMS driver tests are done in sealed or ported boxes where they can't benefit from horn loading or multiple horn coupling.
A ported box will probably be less than 5% efficient (I think 6% is the theoretical limit) wheras a horn can have a much higher efficiency. The other 95% goes as heat.
A PD1850 in a reflex box having a power rating of 800W wouldn't surprise me at all. In a massive stack of horns you probably only have to worry about over excursion by over powering or thermal overpowering them with frequencies where it isn't that efficient.
Im afraid the other 95% dos not all go as heat, there are suspension losses, vibration losses, diffraction losses, there are many reasons why not all the power is transferd into decabels, horns are more effecent as they couple the power fed into the driver too the the air in to the room better, most of the low effecency of reflex cabs is due to the poor coupleing to the air arround the cab.
Im not sure i buy the theroy that a driver in a horn with a small closed rear chamber with have better thermal handleing than the same driver in a big rexlex box.  The driver in the horn will have higher impedance so yes you can apply a higher voltage to get the same about of power through, but it is still the same thickness copper wire, same pole peice, same heatsinks etc.
levyte357 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 17 November 2009 at 1:41pm
Problem is, does driver rms rating generally imply the driver could withstand a prolonged sinewave of the specified Power?
As "a small number of amplifiers", are already identified as capable of delivering this to drivers, given appropriate test conditions.
Meat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Meat Quote  Post ReplyReply Direct Link To This Post Posted: 17 November 2009 at 1:42pm
Yes, a scoops normally a very high efficiency horn so the 25% number may even be better than that. It will also get better as you stack, further increasing your efficiency.
If you're getting more noise out you must be producing less heat for a given power.
Tekasis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tekasis Quote  Post ReplyReply Direct Link To This Post Posted: 17 November 2009 at 1:56pm
Thinking about it, which one would/could take more power, PD1850 or V18-1000 ? & still sound good ?
Edited by Tekasis - 17 November 2009 at 1:57pm
**Heavy Weight-Line**
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timebomb Quote  Post ReplyReply Direct Link To This Post Posted: 17 November 2009 at 1:59pm
Not necessarily, your getting more noise out mainly due to increased acoustic efficiency, bigger radiating area and better coupling of the air to the flux generated in the motor.  the power is lost in reflex cabs due to poor coupling, it dosent all go as heat.
PauliePaul View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PauliePaul Quote  Post ReplyReply Direct Link To This Post Posted: 17 November 2009 at 2:05pm
Testing environment (from the spec sheet).......
"Response measured in a half space environment using a vented enclosure of 164 litres. Please note that frequency response measurements are supplied for comparison purposes only and are not a measure of the low frequency performance which may be achievable in a fully optimised system
Also.........
1. AES Standard (35 to 350 Hz) Program 1600 Watts 2. Sensitivity is derived from the sine wave response between 50 - 350 Hz at 5W/2M using Zmin. It is then scaled to represent 1W/1M. It should be noted that not all manufacturers’ sensitivity figures are based on this AES Recommended Practice. 3. In less demanding applications, the crossover point may be higher. 4. Thiele - Small Parameters follow a 800 Watt preconditioning period.
Enjoy.....
teamrob2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote teamrob2 Quote  Post ReplyReply Direct Link To This Post Posted: 17 November 2009 at 2:41pm
Yes buy you're not producing more heat in the voice coil. You might heat up the air in front of the driver more in a reflex cab than a horn.
Post Options Post Options   Thanks (0) Thanks(0)   Quote teamrob2 Quote  Post ReplyReply Direct Link To This Post Posted: 17 November 2009 at 3:11pm
Power = force x distance moved per second. In a reflex cab the force the driver can push on the air with is less than in a horn (as it has poorer coupling). This means the driver must travel more distance if it's using the same amount of electrical power.
rich_gale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rich_gale Quote  Post ReplyReply Direct Link To This Post Posted: 17 November 2009 at 4:43pm
i never understood the power ratings on the pd stuff.  how can i run 1200wrms into a PD188 (600wrms) all night yet if i do the same thing with an omega pro 18 or even a kilomax things get toasted and i start to smell more than just the glue warming up?
pfly View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pfly Quote  Post ReplyReply Direct Link To This Post Posted: 17 November 2009 at 5:01pm
I've been thinking this efficiency thing...
If I could make a combo of right driver and horn cabinet so it would have efficiency of around 50% through its whole intended bandwith, would it take twice the power since more of the input power would transform into sound and less into heat?
video_compiler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote video_compiler Quote  Post ReplyReply Direct Link To This Post Posted: 17 November 2009 at 5:27pm
Unfortunately it is pointless rating a drive unit in anything apart from full-time RMS, as any other rating will mislead folks.
Meat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Meat Quote  Post ReplyReply Direct Link To This Post Posted: 17 November 2009 at 5:45pm
@ Timebomb: Yes I know there are other loss mechanisms at work other than resistive heating of the coil, thing is if you're getting rid of as much energy in the system as sound as possible (what we want to do anyway) then that energy can't be causing heating in the cabinet because you're chucking it out the front. Unless you think that this is going to lead to large increases in the other losses that you and Rob mention this increased efficiency should lead to less heat therefore higher power rating for the driver in that cab.
If theres more energy coming out of the front then there must be less going to other routes. These things must add up.
