Pd1850 horn handles |
Tee
Joined: 06 May 2022 Location: Ireland Status: Offline Points: 3 |
Topic: Pd1850 horn handlesPosted: 06 May 2022 at 11:40am |
Hello, I am building pd1850s and I have 1 simple question. Can anyone tell me exactly where to put handles in these cabinets..
Thanks in advance T
Edited by Tee - 06 May 2022 at 11:42am |
partya
Joined: 06 September 2013 Location: New Zealand Status: Offline Points: 112 |
Posted: 10 May 2022 at 4:18am |
Depending on which handles you use, they have to be mounted so they don't interfere with the wood used to form the horn.
![]() This arrangement worked pretty well, the side nearest the camera is the top of the 1850, where the driver is mounted. Hope that helps!
Turn it up! Turn what up?
Tee
Posted: 14 May 2022 at 2:01pm |
Thank you this helps a lot T
