  New Posts New Posts RSS Feed - Pd1850 horn  handles
Pd1850 horn handles
Tee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tee Quote  Post ReplyReply Direct Link To This Post Topic: Pd1850 horn handles
    Posted: 06 May 2022 at 11:40am
Hello, I am building pd1850s and I have 1 simple question. Can anyone tell me exactly where to put handles in these cabinets..
Thanks in advance
T
Edited by Tee - 06 May 2022 at 11:42am
partya View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote partya Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2022 at 4:18am
Depending on which handles you use, they have to be mounted so they don't interfere with the wood used to form the horn.
This arrangement worked pretty well, the side nearest the camera is the top of the 1850, where the driver is mounted.
Hope that helps!
Turn it up! Turn what up?
Tee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tee Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2022 at 2:01pm
Thank you this helps a lot
T
