  New Posts New Posts RSS Feed - pd1850 & turbosound floodlight compatibility...?
mkynnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mkynnd Quote  Post ReplyReply Direct Link To This Post Topic: pd1850 & turbosound floodlight compatibility...?
    Posted: 20 June 2014 at 3:25am
hi everyone-- i just picked up some turbosound tsw-718 (floodlight dual 18s) and was wondering if anyone here had experience loading pd1850's into them. would love to hear your thoughts of compatibility and how they came out.
many thanks,
danny
4D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 4D Quote  Post ReplyReply Direct Link To This Post Posted: 20 June 2014 at 9:58am
One rather doubts there will be enough clearance to fit an 1850
THECANDLEMAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote THECANDLEMAN Quote  Post ReplyReply Direct Link To This Post Posted: 20 June 2014 at 10:48am
pd1850 is a great in your face full on bass driver
but running them up to 170 ish to meet floodlight as well as bass, lots of better more musical drivers that will do that wide a range
look at other simillar designs like f218 and usb's and see what drivers are being used in the way you want !!
Motion Systems - Void Airmotion, Airten & Stasys 218 With Powersoft DSP
Hvedstrup View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hvedstrup Quote  Post ReplyReply Direct Link To This Post Posted: 20 June 2014 at 11:50am
PD184 & 186 is the right way to go.
corell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corell Quote  Post ReplyReply Direct Link To This Post Posted: 20 June 2014 at 12:48pm
RCF LF18G401 is IMO great for 18" BPH.
the 1850 will give peaky response in most cases
Teunos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Teunos Quote  Post ReplyReply Direct Link To This Post Posted: 20 June 2014 at 12:57pm
Have heard the PD1850 multiple times in the martin mach ballister MS118 in stacks of up to 18, and i think the peaky response actually is not so bad at all. Sounded great doing deep house and techno. Putting them in the turbosound BPH's will give a good outcome i think in multiples. Putting only singles of any BPH will always be peaky however. Take a minimum of 2 tsw's per side.
Best regards,
Teun.
4D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 4D Quote  Post ReplyReply Direct Link To This Post Posted: 20 June 2014 at 2:12pm
there is not enough room for the massive magnet and you will never get them in through the hatch without carving great chunks out of the woodwork, and then the access panel probably won't fit back on either..
Edited by 4D - 20 June 2014 at 2:12pm
Mark James View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 20 June 2014 at 3:09pm
id second the pd184/186 and maybey even add the 188
not because the 1850 isnt god [or the fact it wont prbably fit] more because well the ciare 6.38mr3 is a lovely mid range driver for a horn. but i wouldnt use it as a scoop driver or sub nt the right tool for the job the 1850 would be best used in some kind f horn or bandpass sub under the turbo bins id ave thught
horn loaded for her pleasure
rich21 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rich21 Quote  Post ReplyReply Direct Link To This Post Posted: 20 June 2014 at 5:23pm
they do fit ... only just but they do fit
but a better choice would be the PD186 or PDN18SB40
PauliePaul View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PauliePaul Quote  Post ReplyReply Direct Link To This Post Posted: 22 June 2014 at 10:53am
PD.188
