PD1850 vs PD1851 - Diffs/Advantages/Disadvantages |
Page <1234 6> |
| Author | ||
godge
Joined: 07 July 2010 Location: Gloucestershire Status: Offline Points: 598 |
Posted: 13 August 2012 at 11:37pm |
I'm yet to draw that much power from mine, running four off an infinite8 but have only seen about 5a draw showing up on the display at peak, looks like I might have to push them a bit harder I think |
levyte357-
Joined: 27 July 2012 Location: UK, South East Status: Offline Points: 8517 |
Posted: 13 August 2012 at 11:46pm |
The point I was making is, The PD1851, PD186, V18-1200, Fane 18XB, all have warm musical tone. The PD1850/V18-1000 have aggressive in your face "gruff", that need "some" param eq to warm them up.
Don't forget, varying music type will effect current draw peaks. ![]() In my case, was 2x 5000VZs driving 8x '50s. Would have required more power to make '51s do same thing, but probably much warmer with less processing. Edited by levyte357- - 13 August 2012 at 11:50pm |
Joined: 02 April 2004 Location: United States Status: Offline Points: 5365 |
Posted: 14 August 2012 at 12:18am |
If the limitation were based on the cabinet size then yes, the drivers you mentioned that sound “warm” would sound similar. However, once you do not limit the cabinet size, there will be a difference amongst the drivers you mentioned on how they sound. Usually 18-inch drivers that offer high sensitivities mean they offer more mid/kick-bass than lower sensitivity 18-inch drivers. That may be a good or bad thing pending on what you are looking to achieve. Best Regards, |
levyte357-
Posted: 14 August 2012 at 12:29am |
The V18-1000/1850 loaded in, compatible horn loaded cabs, will do the lowest sub notes, but with a peaky response, until at least 4x cabs in one stack.. Warmer, less sensitive, lower BL drivers, have flatter response, but lower SPL at lowest notes. |
Thanks(1)
Posted: 14 August 2012 at 12:50am |
If you used the PD 186 it would go even lower than the PD 1850/V18-1000 in a horn. This is due the PD 186 was designed to go lower based on its TS Parameters. A Peaky response is usually due to the limitation of the cabinet size. It is common with large woofers housed in small horns, reflex, and/or sealed enclosures. This is why some resort to smaller drivers where the loudspeaker chassis does not take up 50% of the cabinet it resides in. A woofer in a cabinet that delivers a flat response tells you the driver is in a optimum chamber and, will not need to do a lot of work (due to excessive equalisation) to achieve the a lot of SPL. A good example is a high frequency compression driver on a large exponential horn. Best Regards, |
luton_soundman
Joined: 03 August 2010 Location: Bedfordshire Status: Offline Points: 4550 |
Posted: 14 August 2012 at 4:25pm |
seems like out of the 50' and the 51' one isnt superior over the other, both just very different. so maybe both should be priced the same?
levyte357-
Posted: 14 August 2012 at 4:31pm |
Probably are, to those in upper echelons, who are important enough. ![]() |
MSS
Posted: 14 August 2012 at 4:32pm |
It should be, but it seems like they are very close in price. Not sure what I should load my RX18 with ![]() |
paulus
Joined: 14 December 2005 Location: SOUTH BIRMINGHA Status: Offline Points: 3237 |
Posted: 14 August 2012 at 4:33pm |
@ mss pd1850 all the way, the 51 will sound pants in it
Edited by paulus - 14 August 2012 at 4:34pm |
TRENDSETTER SOUND SYSTEM
levyte357-
If is original RX18s, 1850s. If is RX18DC, sell them. ![]() |
luton_soundman
Posted: 14 August 2012 at 4:36pm |
tall_mike
Joined: 22 June 2012 Location: surrey Status: Offline Points: 643 |
Posted: 14 August 2012 at 5:03pm |
Looks like the 1851 is built to higher excursion tolerances but the compromise is probably lack of cone control at the extremeties of this excursion. Unless the magnet is much deeper, doesn't look it though?
Power handing may be higher, but that's because they're more than a db less efficient - so they generate more heat to get the same output. |
Page <1234 6> |
