  New Posts New Posts RSS Feed - PD1852 in 1850/186 Horns
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Topic: PD1852 in 1850/186 Horns
    Posted: 18 July 2023 at 12:06pm
Did anyone ever try this?
Have 4x PD1852s I'm thinking about selling, unless they work in these, of course.
luton_soundman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote luton_soundman Quote  Post ReplyReply Direct Link To This Post Posted: 18 July 2023 at 4:39pm
Did the 186 have the bigger chamber? Be interesting hearing them with 52s
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 19 July 2023 at 8:18am
Yep..
Don't know if many have tried these cabs with modern stronger drivers.
With the drivers suggested by the plans, both 1850/186 Horns are 50hz boxes, simple as that.
I've heard them in stacks of 4x/8x, with "older" drivers, and they stil don't go much lower.
But have heard them used in Carnival on floats, and they were perfect for that, as they can play higher than Scoops.
Needs a driver with  exceptional Xmax/BL, and cone strength to do more, and also driver with T/S  suited to smallish chamber and horn throat.
V18-1000 is on paper perfect for these cabs, but PD1852 will be warmer, should naturally play lower, due to difference in right T/S parms.
Just as it plays warmer than PD1850, in same cabs.
Edited by levyte357- - 19 July 2023 at 10:37am
