  New Posts New Posts RSS Feed - pd186/3 in 186 horn
pd186/3 in 186 horn
BrainlessTekno View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrainlessTekno Quote  Post ReplyReply Direct Link To This Post Topic: pd186/3 in 186 horn
    Posted: 21 February 2023 at 11:51am
what do you think about this? will it fit ?
also, is there a connection between 1850 horn and pd1850 or 186 horn and pd186, what does the numbers mean or is it just a coencidence? like i have a feeling that 18 meand that its 18incher but what about rest?
DMorison View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote DMorison Quote  Post ReplyReply Direct Link To This Post Posted: 21 February 2023 at 1:28pm
The names come from the Precision Devices drivers they were originally designed to use.
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 21 February 2023 at 2:09pm
This question could have been asnwered, by looking at the below 2x links, and reading previous posts on this forum.
https://www.speakerplans.com/index.php?id=1850horn
https://www.speakerplans.com/index.php?id=186horn
The PD186 mentioned in the 186Horn plan, was for a MK1 PD186.
That is completely different from the current PD186/MK3.
As I warned you in "another thread", less than 48 hours ago, finding cheap drivers, and asking if they will work, is not a wise approach, for driver selection.
Try less posts, and more reading of relevant posts in the 186/1850 Horn forum, about comments regarding choosing drivers.
PD1850 Mk2 (Not PD1850/3), will be great driver in 186 Horn.
These can be had used, for approx £250 GBP. They will be better in this cab, than the cheap reflex drivers, you keep digging up.
Don't know anything about 1850/3, except it is very different to previous model.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrainlessTekno Quote  Post ReplyReply Direct Link To This Post Posted: 21 February 2023 at 3:03pm
Sorry for overposting.
okey i did not know there is such a difference between 186/2 and /3
BigSoundNorthWest View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote BigSoundNorthWest Quote  Post ReplyReply Direct Link To This Post Posted: 22 February 2023 at 12:22pm
Edited by BigSoundNorthWest - 22 February 2023 at 12:24pm
