PDs vs Void 18" |
Page <1234 7> |
| Author | |||
adambomb
Joined: 10 April 2006 Location: United Kingdom Status: Offline Points: 3220 |
Posted: 27 March 2008 at 11:47am |
it has lighter cone... therfor not built for high compression boxes (like front loaded horns)... doesn't mean to say its not suited to "real bass applications".
Jake_Fielder
Joined: 08 October 2007 Status: Offline Points: 4236 |
Im not sure doing a test on a bench will prove anything?
You certainly cant prove how strong the cone is without breaking one!!
tweeter box
Joined: 21 October 2007 Location: United Kingdom Status: Offline Points: 6784 |
Posted: 27 March 2008 at 11:59am |
Hi Adam, what box would you recomend to me for this driver?
True, i guess i might just take it round to see what tests he has in mind. |
Disco Stu
Joined: 03 March 2005 Location: United Kingdom Status: Offline Points: 2492 |
Posted: 27 March 2008 at 12:10pm |
I dont think the issue is the flimsy cone, there are plenty of drivers like Fane XB that go in front loaded horns and last years without any problems. I think the main issue is the fact that you need a mighty big box to get the best out of these, and dont forget Rog designed this driver primarily for the Stone Love Scoop as I recall, so a rear loaded horn is going to be the optimal enclosure, the best parameters of which would have to be experimented with but I expect something with a larger chamber will work best. Stu Edited by Disco Stu - 27 March 2008 at 12:11pm |
All you need to know is:
Sensitivity + Power Handling - Power Compression = Max Output My acts: www.myspace.com/thebowiexperience www.myspace.com/scheisseelektronisches |
adambomb
Posted: 27 March 2008 at 12:37pm |
with stu... they were designed for stone loves scoops.. so they must be suited to that type of cab.
Rog has mentioned this driver a few times... with many hints / tips... have a search!
levyte357
Joined: 10 May 2004 Location: UK, London Status: Offline Points: 11743 |
Posted: 27 March 2008 at 12:59pm |
The PD is more of a general purpose driver than a V18-1200. It's parameters tell you it is often strong enough to handle cabs it wasn't designed for. The V18-1200 was deisgned to be a scoop/reflex driver. It needs a big reflex cab, or scoop with right Chamber/throat to really perform. Tighter drivers will tolerate large chamber scoops if they have enough BL and Xmax, looser drivers "mostly" do not like small throat scoops/small volume reflex cabs. It is actually not that difficult, to design scoops/reflex cabs that V18-1200 would perform well in. |
Tekasis
Posted: 27 March 2008 at 1:17pm |
I believe it's much more than that.
PD1850's are the benchmark for real sub drivers.
No matter how many sl*g them off, when a manufacturer decides to come out with a new driver, more than likely, at the back of their mind PD's are always there.
PD1850 in a Hog Scoop or in a Mini-Scoop with large chamber, not many can test.
The other day a Turbomax 900 in Shortman's full scoop & PD1850 in his Mini scoop performed much better than a v18-1200 in the same scoop.
As asked before, why is everyone selling them!!! Sensitivity ?
**Heavy Weight-Line**
A home without books is like a body with no soul. |
tweeter box
Posted: 27 March 2008 at 1:28pm |
Hard time selling them aswell, thanks Teks that was the point of this thread, i was curious as to why nobody wants them, when theyre so highly spoken of.
Thats why i wanted to do some tests of my own as i dont believe Rogs plots when comparing PD1850 to V1200 to be correct. (no disrespect intended).
Jake_Fielder
Posted: 27 March 2008 at 1:31pm |
what plots are those? link?
Tekasis
Posted: 27 March 2008 at 1:35pm |
What I can't get is at Levy's v18-1200 shoot-out / testing it devastated the place in a Mini-Scoop, so how comes the PD1850 is still up there & both the Turbomax's creeping up for the crown!
RX18 & Turbomax 900/1200 may surprise a few here!
tweeter box
Posted: 27 March 2008 at 1:41pm |
Thankyou yet again Sir Teks.
Thats just my point, we always hear PD or Turbo etc done damage in this n that scoop but never V1200 when aparently its supposed to be design around a scoop!
I wanna get to the bottom of this and if it turns out that V1200 does do damage in a particular or even a hand full of scoops then i think credit should be due. Yes?
tweeter box
Posted: 27 March 2008 at 1:43pm |
Here you go Jake;
Page <1234 7> |
