Peak limiting for driver protection |
Page <1 23456> |
Augusts ![]() Registered User ![]() ![]() Joined: 07 January 2017 Status: Offline Points: 150 |
Thank you
Im sorry, it seems people are getting cranky because of my post
Earplug ![]() Old Croc ![]() Joined: 03 January 2012 Location: Europe Status: Offline Points: 6949 |
"I am telling you guys, the speaker hit the back plate because, the Vpeak was 141Volts for a 4ohm driver. that is 6000w" R = 4 ohm, nominal resistance! In real life, your speaker becomes a complex impedance that will vary with frequency. Do you understand the difference? Some manufacturers supply an impedance curve with their products, but put the driver in a box and that changes again. The only way to find out is to measure - or get one of those modern, fancy amps that tell you! ![]() Like I've already said, do a sweep test with a signal generator and see what going on. |
Yes, I know it is a nominal resistance. I know what are you saying, thank you, I have recalculated the resistance to a precise 4ohms for the convenience of using treshold calculators. I think the problem could have been that I had set a too long of an attack time for the limiter. Something must have gone through the limiter.
Edited by Augusts - 28 December 2022 at 12:54pm |
smitske96 ![]() Young Croc ![]() Joined: 16 February 2016 Location: The Netherlands Status: Offline Points: 979 |
What kind of cabinet + driver are we talking about? With some drovers its impossible to hit the backplate due to the spider limiting travel.
snowflake ![]() Old Croc ![]() Joined: 29 December 2004 Location: Bristol Status: Offline Points: 3012 |
excursion varies with frequency. What about applying dynamic eq or sidechain compression?
Ok, you obviously (now) have it under control. Good luck! ![]() |
Elliot Thompson ![]() Old Croc ![]() ![]() Joined: 02 April 2004 Location: United States Status: Offline Points: 5069 |
Yes, Give up. You do not have any experience on the issue August is facing. It's that simple! ![]() Best Regards, |
Some drivers that offer dual spiders can have one fail. The end result is one driver moving stronger than the other drivers within the chain. Best Regards,
If you have a spider fail on you due to excursion, you are well passed the limit of something bearable to listen to.
I use peak limiting more as the max before it is going to sound crap. |
Esc4pe ![]() Registered User ![]() ![]() Joined: 08 August 2021 Location: England Status: Offline Points: 148 |
Toasty’s posts have been an absolute godsend for me (and I’m sure countless others) while learning throughout the years. This poor attempt of trolling should be considered blasphemy as far as I’m concerned ![]() I know who I would take advice from. My simpleminded 2 cents that no one asked for: could you take more kit to the events and run with less power instead of ragging a smaller amount and surely won’t run into this problem then? I never damage drivers and rarely use any limiting at all? To bottom out a driver is quite a task, Elliot does raise a point that they may be becoming unloaded due to improper setup maybe?
Edited by Esc4pe - 29 December 2022 at 12:49pm |
bob4 ![]() Old Croc ![]() ![]() Joined: 29 February 2004 Location: Finland/Germany Status: Offline Points: 1766 |
Interesting topic, and first of all, happy to see that August has found a practical solution to his problem!
However, I don't understand this repeated statement of yours. You probably refer to the impulse peaks of the full range audio signal. Your woofers are acoustically capable of playing back frequencies up to 1- 2 kHz. Yes, if you played a FULL RANGE signal through your woofers, they would roll of somewhere around 1-2 kHz. That part of the signal also contains a lot less energy in relation to the bass, and would be insignificant. So for INPUT limiting of full range signals, your statement is correct. But all that is completely irrelevant to the subject of bass signal lmiting! In your dsp, i suppose you are using a dedicated OUTPUT limiter on the subwoofer channels output that sees a filtered bass signal only. That limiter only sees sub frequencies, lets say 30-120 Hz. That signal still has peaks, obviously. There is no part of that filtered signal that will be "too fast" for the woofer to follow. So you HAVE to consider the peak part of your subwoofer signal. The waveforms will probably be quite close to a sine wave, due to the narrow bandwidth the signal will contain only a fundamental and one or two overtones (e.g. 35, 70, 105 Hz). As toasty quoted, typically 6 dB crest factor. I suppose that the optimum solution would be to set your rms limiters so that your subs stay within xmax most of the time, and set the peak limiter to reign in the cone somewhere between xmax and xmech, before it hits the back plate. Prevention of power conpression could also be considered. As others suggested, reviewing the low corner of your cabs and hpf setting would probably help as well. Frankly, you have not provided enough information. What kind of cabs? What was your test signal in your excursion tests? Music? Bass drums/impulses? Sine waves? In your inquiry, you have also omitted the time constants of the limiter(s). Toasty's replies, as always, thorough and exhaustive ![]() Happy to learn more ![]() Edited by bob4 - 30 December 2022 at 8:19am |
Pasi ![]() Old Croc ![]() Joined: 25 April 2010 Location: Knutsford Status: Offline Points: 2730 |
Edited by Pasi - 31 December 2022 at 12:16pm |
Page <1 23456> |
