Peak limiting for driver protection |
Page <1 3456> |
Author | |||
Augusts ![]() Registered User ![]() ![]() Joined: 07 January 2017 Status: Offline Points: 152 |
The problem was too long of an attack time for the Xilica DSP. I had set it to 20ms. I should have been 10ms, as it is crossed at a 100Hz
I like to limit everything because you newer know what kind of people are behind the decks and Im not a millionaire, I can't afford 50 L'acoustics subs. I use what I build myself ![]() |
spongebob ![]() Young Croc ![]() Joined: 20 October 2010 Status: Offline Points: 1394 |
Please leave this forum Elliot, otherwise you'll drive others who have intelligent answers away |
smitske96 ![]() Young Croc ![]() Joined: 16 February 2016 Location: The Netherlands Status: Offline Points: 1009 |
@August
What was the driver failure?
Father-Francis ![]() Old Croc ![]() ![]() Joined: 24 October 2007 Location: Kenya ,Denmark Status: Offline Points: 2753 |
@smitske The problem was with FaitalPro 18HP1030. Thankfully there was no failure but I heard the voicecoil hitting the backplate. Since then I thought that it was because I hadn limited the peak power on the amp which I did thus lowering also the rms. But after reading the articles here and talking to a few people I now know that it was the attack time and not the peaks. I set the peaks +6db as it should be
Edited by Augusts - 03 January 2023 at 11:57am |
Wasn't there any audible distortion before that point? Because it should definately be there.
It was Muslimgauze his squarewave synth, since they never play something like that in the club, I discovered this while doing mh tests and it happened really fast
bob4 ![]() Old Croc ![]() ![]() Joined: 29 February 2004 Location: Finland/Germany Status: Offline Points: 1783 |
Which track? Need it for reference ![]() For subbass testing, try to find "Judgement Dub" by Rog Mogale. It contains strong bass down to 30 Hz, and towards the end even deeper, iirc goes down to around 20 Hz
Elliot Thompson ![]() Old Croc ![]() ![]() Joined: 02 April 2004 Location: United States Status: Offline Points: 5086 |
Haters are going to Hate ![]() At least Toastyghost tried to help. You on the other hand.... What did contribute to Augusts dilemma again? ![]() Best Regards,
@Bob4
It could have been something like this but I dont remember the exact track, but he has alot of stuff that could destroy subs. Thanks for the Judgement track!
Edited by Augusts - 03 January 2023 at 3:22pm |
snowflake ![]() Old Croc ![]() Joined: 29 December 2004 Location: Bristol Status: Online Points: 3061 |
that's not really the issue. And frankly if people don't have a better answer than what others have posted it is better that they contribute NOTHING on that topic. I think you are being called out for persistently acting like a bit of a know-it-all and dispensing advice to new members which doesn't really stand up to scrutiny - and then has to be corrected by others. You do make interesting posts now and then but often you seem to be afflicted by Dunning-Kruger.
Edited by snowflake - 03 January 2023 at 5:25pm |
jammin75 ![]() Old Croc ![]() ![]() Joined: 08 July 2012 Location: west midlands Status: Offline Points: 2354 |
Page <1 3456> |
