Peak limiting for driver protection |
Page <1 456 |
spongebob ![]() Young Croc ![]() Joined: 20 October 2010 Status: Offline Points: 1387 |
I just read and observe on here unless I know (not believe) any comment would be constructive and helpful For example, I know you not posting such drivel would be helpful, as apposed to believing it to be true |
Augusts ![]() Registered User ![]() ![]() Joined: 07 January 2017 Status: Offline Points: 150 |
The track does not download
Could you put it up on wetransfer??
I usually play around with these
Ben Buitendijk - Side StEPping Ben Buitendijk - Near Mint [OBQ002] Aleksi Perälä - Ovuca Bonus - 05 Stochastic Process Aleksi Perälä - Ovuca Bonus - 07 Hydrophobic Effect Aleksi Perälä - Ovuca Bonus - 03 Kinetic Theory Oxia - Story mathew_jonson-pirates_in_the_9th |
In forums, not always you get a straight answer, but I believe a group of people thinking about the subject make the collective subconscious shift. In this case a local sound engineer and also a PA speaker designer helped. Actually I knew this already but we refreshed our memories and hopefully now the subs are safe and also have a optimistic spl
@smitske
Yes there was a lot of port noise :) I thought I had designed the boxes improperly, bet when I concluded that they are taking a hell of a beating than the port noise stopped, and there were no more over excursion problems And now recently, because I recenty concluded it was the attack time - at around 100hz the woofer made a really nasty cranking noise on the kick. with 10ms now its fine. God must have been watching over me, thanks old man!
Jo bg ![]() Young Croc ![]() Joined: 08 March 2017 Status: Online Points: 547 |
It is not haters. It is people sick of reading your wrong advice based upon surpassed knowledge, or your bashing of good information, just because you don't understand it.
It may be viable for you to work as it still was the seventies, and dismiss all the knowledge that is available nowadays, but you are harming all the newbies coming by and reading your posts when you push your old man tecnique as the only one. It becomes ridicule when you try to reply Toasty while clearly not even understanding what you read.... Not a hater. Just someone sad for the disservice you are bringing to the comunity and you anti scintific approach... To science.
@jammin75 got it, sorry
jammin75 ![]() Old Croc ![]() ![]() Joined: 08 July 2012 Location: west midlands Status: Offline Points: 2343 |
good i knew it was on hardrive sum where maybe useful to others
for a speaker that reaches xmax at a 1000W ,I would set a limiter treshold @500W and +6db until it reaches peak brick wall limiter. Then the coil would stay in its magnetic field even if someone starts playing live synths, raw sinewaves. I would not overheat also, I think. Why bring more boxes if you can do the job with four, knowing exactly where the limit is. |
Page <1 456 |
