Peavet 4xt crossover points |
MARTYNJONHALL ![]() Registered User ![]() Joined: 02 January 2005 Location: Burton On Trent Status: Offline Points: 299 |
![]() ![]() ![]() ![]() ![]() Posted: 23 October 2019 at 3:01pm |
Hi guys
Anybody know what the crossover points are in the peavet 4xt's? Are the crossovers built in 2 or 3 way?
smithshorn ![]() Registered User ![]() Joined: 08 February 2007 Status: Offline Points: 242 |
300 and 1200. 12db slope on mid, and 18db slope on high frequency. According to Peavey website.
njw ![]() Old Croc ![]() ![]() Joined: 26 March 2010 Location: S. Wales Status: Offline Points: 2439 |
Quasi three way, so both 2 and 3 way, sort of, or 2.5 way according to some manufacturers (
So I have took mine apart and the 2 15's are wired in parallel on mine?? ![]() |
Hmm, it would seem they aren't quasi 3 way then as I thought. I'm not sure if I just can't make it out in the picture but it doesn't look like you have the HF protection bulb on the crossover either?
Apparently the American SP ones are 3 way, the uk ones are different. I had not noticed the bulb missing. I will open another one up tomorrow as I know some of my others have the bulb. I was going to go down the route of bi amping them
Conanski ![]() Old Croc ![]() ![]() Joined: 26 January 2006 Location: Canada Status: Offline Points: 2019 |
That isn't a PV crossover and if I was guessing I'd say it could probably only handle about 150w.
To be honest, the reason I want the crossover point for the horn is so I can bi amp the cabs
The crossovers could come out then
The HiSYS 4xt user manual I found online(is that what you have?)says to use the Peavey PL-1200 active crossover module when bi-amping with CS series amplifiers, that is a 1.2khz 18db/oct crossover. |
Robbo ![]() Old Croc ![]() Joined: 05 December 2005 Location: Shropshire Status: Offline Points: 4098 |
Peavey UK used to build certain cabinets including HiSYS 4 in the UK so they may be fitted with different spec Xovers compared to the original USA built cabinets---In the past, I have removed Peavey cabinets from installs and some have had totally different Xovers compared to others but they have all been genuine factory Xovers--usual giveaway are the multipin connectors that they use.
