  New Posts New Posts RSS Feed - Peavey MB--2
Peavey MB--2
Pierre-Marie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pierre-Marie Quote  Post ReplyReply Direct Link To This Post Topic: Peavey MB--2
    Posted: 12 May 2010 at 8:30pm
Good evening everyone.
I am Pierre Marie from France and it is my first subject on your forumHandshake
I seek the plan of Peavey MB-2, I have here for my home cinema of the FH-2/MB-1 and a FH-1 for the central speaker but does not  here to France to find the plan of the MB-2 which seems rather easy to build.
Thank you very much and sorry for my written English who is as good as the little the automatic translator: -)
Regard.
Pierre-Marie.
_djk_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2010 at 4:02am
It's just a couple of boards at a 90° angle, nothing special.
http://www.peavey.com/assets/literature/manuals/80301016.pdf
djk
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pierre-Marie Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2010 at 7:31am
Hello _djk_Smile
And thank you for the pdf.
I would like to have the length of the horn his angle and the depth of the right part at the bottom, the size of the opening for the speaker as well as the late volume of the speaker, if somebody here had one of them?
Pierre-Marie
Edited by Pierre-Marie - 13 May 2010 at 7:40am
Mhamplification View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mhamplification Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2010 at 8:59pm
Now thats what I call a home cinema
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2010 at 8:58am
To risk repeating myself:
"It's just a couple of boards at a 90° angle, nothing special."
The width of the tunnel is about 10.5", the mounting plane for the 12 has a 10.5" opening in it, and is spaced so the driver is all the way towards the rear of the cabinet.
Some 90° plywood horns I put together one Sunday afternoon:
djk
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pierre-Marie Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2010 at 6:23pm
 Hello
Thank you very much for your information.
I did that quickly by deducing the dimensions from the images which I found on the Net.
Pierrot
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2010 at 12:44am
That looks like the animal!
djk
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mhamplification Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2010 at 7:52pm
here are the pages from a 1979 Peavey PA catalogue
Ibex View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ibex Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2010 at 1:20am
Where can I find more information aout these vintage peavey systems?
Are there plans for the HDH/FH-1/FH-2 cabs available?
Mhamplification, would you be so kind to post more pages of this 1979 Peavey catalogue? (i.e. HDH-1 system)
Any other pix of these oldschool rigs?
gzg
Drapetsoniths View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Drapetsoniths Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2010 at 4:11pm
The mh2 states 110 db sensitivity from two 15"?WackoHow could it be?do they mean eigth space or something?
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2010 at 12:14am
"How could it be?"
Easy, 200hz with two 4 ohm woofers and 2.83V
djk
Post Options Post Options   Thanks (0) Thanks(0)   Quote Drapetsoniths Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2010 at 12:35am
Oh yes,the 200 hz trick,that actually slipped my mind!
On the power side they state 1 watt (on the features list).
2.83 v to 2 ohm=4watt and that would be pretty dishonest Dead
Edited by Drapetsoniths - 20 May 2010 at 12:36am
