  New Posts New Posts RSS Feed - Peavey PV-4C Cutting out?
Jake R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jake R Quote  Post ReplyReply Direct Link To This Post Topic: Peavey PV-4C Cutting out?
    Posted: 30 June 2012 at 12:14am
Hi,
I have a Peavey PV-4C and it is being used as a monitor amp with two 16ohm HK Monitors wired in parallel and a 8ohm ALTO speaker. It keeps cutting out when being used- The DOT Active comes on for a sec and then the Green power LED goes off 2 secs later it comes back on. All sound is lost when this happened. It occurs a dozen times a show. Any ideas?
Thanks
Jake
Tan-2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tan-2 Quote  Post ReplyReply Direct Link To This Post Posted: 06 July 2012 at 8:02pm
The pair of 16 ohms speakers wired to 8 is fine, and the 8 ohm put on the other channel should work just as good..
just one thing, does the the amp cut off with no speakers connected?  as it might be 'seeing a sort some where so try it with out a  load..... amps some times cut out if there's a sort connection made some where..
You can down load the schematic on line to check things out or email peavey for it...
