Peavy Hisys XT crossover help. |
Shortrope ![]() Young Croc ![]() Joined: 08 July 2013 Location: Ireland Status: Offline Points: 1232 |
![]() ![]() ![]() ![]() ![]() Posted: 14 August 2019 at 11:26am |
This is a long shot but I’m trying to do a favour for a pal and repair his old Peavey crossover.
I need to find the spec for this Thermistor. ![]() ![]() |
cravings ![]() Old Croc ![]() ![]() Joined: 30 January 2007 Location: Ireland Status: Offline Points: 7170 |
does he have a second one the same?
Urrgh!...Face+Palm...I didn't think of that! It's a 40min drive away and I was there yesterday.
he could take a photo of it.. it probably says something on it..
studio45 ![]() Old Croc ![]() ![]() Joined: 16 October 2007 Location: United Kingdom Status: Offline Points: 3820 |
Perhaps more likey to be a Polyfuse rather than a thermistor? A thermistor that small wouldn't really have a place in a high powered crossover circuit, whereas a 1 amp Polyfuse is about that size and would offer useful protection to the HF driver, if it's in series?
Yeah you're right I don't think it's Thermistor now either. I was wondering if it's a Ceramic Capacitor.
Again, at that size, it could only be a few hundred pF at most - so not gonna be doing much filtering in a low-impedance circuit....
I also see what looks like a dry joint at the bottom centre of the board (dark ring all the way around the component leg) If you can sketch out a schematic, and the mystery component is indeed in series with the HF and in parallel with that light bulb, then it's a classic Polyfuse protection circuit. When the Pfuse opens, all the current has to flow through the bulb, which will drop the excess power, and then blow itself if you're really silly or your amp is oscillating. In which case, I would try replacing with a 500mA Pfuse and see if that works.
tomr_29 ![]() Young Croc ![]() ![]() Joined: 23 February 2009 Location: West Midlands Status: Offline Points: 540 |
Yeah this is a polyfuse. I’ve replaced a few on a number of Peavey Hisys crossovers. Typically have used a 250mA and actually still have a few left. The part number on the pack is 647-8443 (RS components part number).
Proper capitalisation is the difference between helping your Uncle Jack off a horse and helping your uncle jack off a horse.
www.facebook.com/tremoracoustics |
Legend! Thanks a million!
Five & ![]() Registered User ![]() ![]() Joined: 22 May 2008 Location: Caribbean Status: Offline Points: 142 |
Polyswitch For Peavey Soundguard HF Protection Circuit Part # Rxe030 (X030) |
Let The Music Play
VECTORDJ ![]() Registered User ![]() ![]() Joined: 11 June 2006 Location: United States Status: Offline Points: 386 |
I thought it was RXE035 but poster that says RXE030 may be right. I always thought the value was too low. It must latch and send the power to the bulb as soon as You crank it up. 030 will trip/latch at .60 amps. Any other ideas??
