  New Posts New Posts RSS Feed - Peshkov Sub - Scoop / Tapped / ARLS???
 Post Reply Post Reply Page  <12345>
Ibex View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ibex Quote  Post ReplyReply Direct Link To This Post Posted: 15 June 2009 at 6:23pm
Originally posted by Peshkov Peshkov wrote:
Originally posted by Ibex Ibex wrote:
Why did he finally change to one WSX? ...cause of lower cut-off frequency?
Did you also engineer the top on these 3 subs shown on the pic?
Yeah, WSX is much lower than this microbes with 65Hz cut-off frequency (for 3pcs)/
 The problems with "quick" LF was eliminated  after a birth of this 3-way sat (MB-2x10"/MF-10"/HF-2").
and finaly, i don't like a scoop-constructions subs because of its questionable compromise. I think that freq band widening in all types of lspk is not justified.
My simulation of 3 micro-subs says that they can do 60Hz@-3dB...?
I also made a comparison with one WSX.
I thought that the WSX only works in an array of min. 4 pcs.?
If i can trust my simulation skills, then one WSX has an -3dB of 73Hz...?
Micro Scoop downscaled x3 vs. WSX - SPL
The top looks very interesting too!
What's the 3-way sat able to do with it's 2x10" MB-section (-3dB)?
How do the 2 slot-loaded MB work? Are they reflex-loaded and mounted inside the port?
Do you have a thumbsketch?
bitzo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitzo Quote  Post ReplyReply Direct Link To This Post Posted: 15 June 2009 at 6:40pm
I'm sorry Ibex but stipe microscoop like the hog scoop aren't only a scoop because the driver is in the horn mouth like a tapped horn. But if you change the driver arrangement in tapped horn, you can't sim the combined response.
Ibex View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ibex Quote  Post ReplyReply Direct Link To This Post Posted: 15 June 2009 at 8:26pm
Hy bitzo!
Your reply is justified, but i thougt that it would be correct to model it as an FLH with a path difference (only 11cm) in the combined response, because the rear of the driver is mounted in a rear chamber and not inside the horn.
But as we can see in the next simulation, i failed with my speculation Cry
I'm happy that the difference isn't too big! Cool
Question Does anybody know why the two simulation aren't congruent??? Question
So, here the the hornresponse input data for the downscaled Micro Scoop loaded with the 18Sound 12LW1400 modelled as a tapped horn, followed from the comparison of the response to the RLH version:
Micro Scoop downscaled tapped - 18Sound 12LW1400 - Hornresponse Input Data
Micro Scoop downscaled - 18Sound 12LW1400 - SPL Tapped vs. RLH
black = tapped
grey = RLH
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitzo Quote  Post ReplyReply Direct Link To This Post Posted: 15 June 2009 at 9:02pm
The driver is mounted in the horn mouth and has a rear chamber. IMHO , tapped or rlh, both aren't the correct drive arrangement. Compound neither fit with this cab, I'm not english and I've learned by myself using HR so I don't understand very well the offset driver arrangement, but it's the last one....or perhaps HR has its limit
Ibex View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ibex Quote  Post ReplyReply Direct Link To This Post Posted: 15 June 2009 at 9:31pm
Question Maybe the tapped and the scoop plot  are different because of marginal unequal hornflares? Question
ARLS, Tapped Horn, RLH (with driver mounted inside the mouth)...
They are all congnitional, with special parameters:
- big or small rearchamber or no chamber
- long or short hornlength
- low or high flare rate
- rear of the driver firing through the chamber into the hornthroat or direktly into the  beginning of the  horn
I think the offset driver arrangement won't be targeting (in the case of a FLH like the punisher or afterburner it would be correct to use this function).
I also learned HR by myself.
TDA-Audio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TDA-Audio Quote  Post ReplyReply Direct Link To This Post Posted: 15 June 2009 at 9:43pm
Макс - Welcome
ты хоть и вынужден быть менеджером -но я уверен - дух инженера в тебе жив!!
Edited by TDA-Audio - 15 June 2009 at 10:00pm
Ibex View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ibex Quote  Post ReplyReply Direct Link To This Post Posted: 16 June 2009 at 8:00am
Originally posted by TDA-Audio TDA-Audio wrote:
Макс - Welcome
...seems that you know each other?
TDA, what do you as a pro-engineer think about my point of view on the miscellaneous cab designs? Where is the leak in my assumption? Why aren't the responses congruent?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mobiele eenheid Quote  Post ReplyReply Direct Link To This Post Posted: 16 June 2009 at 10:32am
Quote Maybe the tapped and the scoop plot  are different because of marginal unequal hornflares?
The tapped and scoop plot are different because the scoop plot doesn’t take the “tapped horn effect” into account, whereas the tapped plot does.
From a simulating perspective, simulating as a scoop (with or without taking the path length difference into account) is less accurate (double checked that with McBean a long time ago).
The biggest difference between an ARLS-type hybride and a tapped horn is that the ARLS-type trust more on the large Vtc to get a decent low frequency response, whereas “normal” tapped horns only have a Vtc in the order of several liters. Give a tapped horn less length and a larger Vtc and practically you get an ARLS.
Recently I’ve measured multiple hybrides with variations in both the horn length and chamber size (effectively variating it between an ARLS and a Microscoop), all showed more correspondence with the tapped plot then the scoop plot. I.e. 2 (bumpy) peaks at both the high and low cut off. The depth inbetween the peaks is more pronounced with a 15” then with a 18” in the same model and also slightly dependant a how the cabinet is placed.
Quote The driver is mounted in the horn mouth and has a rear chamber. IMHO , tapped or rlh, both aren't the correct drive arrangement. Compound neither fit with this cab, I'm not english and I've learned by myself using HR so I don't understand very well the offset driver arrangement, but it's the last one....or perhaps HR has its limit
Driver arrangement – Offset: Newer feature to calculate a horn where the drive isn't firing straight down the horn but rather starts further down the horn from the sides. I.e. the 1850 horn, CV-style fold, Punisher, etc. S1 – S2 = horn before (the middle of the) driver, S2 -S3, etc. = horn after driver. Compression ratio = Sd/S2.
Best regards Johan
Edited by mobiele eenheid - 16 June 2009 at 10:34am
Ibex View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ibex Quote  Post ReplyReply Direct Link To This Post Posted: 16 June 2009 at 11:05am
Best regards Johan
Thanks for your explaination of simulating the tapped effect!
I have to agree your argumentation.
What i noticed in my simulations is that drivers with a low resonance frequency an heavy wighted cones aren't the right ones vor an tapped cab design, these would cause a peaky response too.
What were your auditory impressions of Tapped/ARLS/Micro Scoop designs?
So, what you say is that a MicroScoop doesn't work like a real Scoop...?
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitzo Quote  Post ReplyReply Direct Link To This Post Posted: 16 June 2009 at 11:35am
many thanks joahn, very clear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mobiele eenheid Quote  Post ReplyReply Direct Link To This Post Posted: 16 June 2009 at 12:34pm
Quote What i noticed in my simulations is that drivers with a low resonance frequency an heavy wighted cones aren't the right ones vor an tapped cab design, these would cause a peaky response too.
Indeed, afaik a driver is optimum if it has an Fs that is 1.414 times as high as the desired low frequency cut off (when used in a tapped horn).
Quote What were your auditory impressions of Tapped/ARLS/Micro Scoop designs?
For regular tapped horn: effortless, warm bass, no perceived throw.
ARLS, Microscoop: It bears the sound (and the frequency response) of a 6th order band pass cabinet. Much lower sounding then simulated. Noticeable less bass perception a sides and behind the cabinet then in front.
Quote So, what you say is that a MicroScoop doesn't work like a real Scoop...?
They’re both RLH’s but the Microscoop has some “tapped effect” whereas the scoop doesn’t.
As the horn flares faster, at the part where the driver (near the horn mouth) is located or as the horn mouth becomes larger, the less pronounced this “tapped effect” becomes.
Based on this, the tapped effect for a HOG would be aspected to be less then for a Microscoop. The flare rate for the Microscoop is also pretty high at the drivers entry point near the mouth.
A HOG with a infinitly fast flare near the driver at the mouth essentially becomes a scoop, the Microscoop a miniscoop.
Best regards Johan
Ibex View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ibex Quote  Post ReplyReply Direct Link To This Post Posted: 16 June 2009 at 2:24pm
Johan, a big thank you for your vivid avowal!!! Very interesting!!!
Does the rear chamber also influence the tapped effect?
The most tapped horns doesn't have a rear chamber, on the other hand hog or mircoscoop have a chamber. Shouldn't it be possible to let the rear side of the driver fire directly into the beginning of the horn? Or would that be counterproductive?
Sorry to pepper you with questions, but it seems to me that you know what you are talking about.
greez
