Peshkov Sub - Scoop / Tapped / ARLS??? |
Page <1 345 |
redmanchin
Joined: 20 November 2012 Location: Orlando Status: Offline Points: 5 |
Posted: 20 November 2012 at 6:17pm |
I have a Question.. Can someone tell me which is better? A super scoop or a hog scoop?
smitske96
Joined: 16 February 2016 Location: The Netherlands Status: Offline Points: 1217 |
Posted: 09 September 2016 at 10:12am |
I know this thread is very old, but I still have a question.
I'm in possession of 4 DAP X15Hl subwoofers, and they are the same as the staiper micro scoop. The original DAP replacement driver's cost around 350 euros, sow they aren't very cheap.. Are there other alternatives, that could give me some more SPL? For amplification I have a NEXT MQ10000. TS parameters original driver: fs : 43,6 Re: 6,1 Qms:6,453 Qes:0,411 Qts:0,387 Vas:79,16 Cms: 76,2 Rms:7,432 no: 1,538% Sd:855,3 Xmax: 8,5 mm Le @1kHz :3,8 EBP: 106 Sensitivity @ 2,83 V (8Ohm) : 95,2 dB @ 1 m Sensitivity @ 1 Watt : 94,01 dB @ 1 m Power handling: 600 Watt RMS. It doesn't have to be an neo driver, as the cabinet on itself weighs enough .Sorry if my english isn't perfect.. |
mobiele eenheid
Joined: 15 August 2004 Location: Netherlands Status: Offline Points: 1563 |
Posted: 09 September 2016 at 4:21pm |
Considering you'd like more output, I would suggest the Beyma 15SW1300Nd or the 18Sound 15LW1401 (ferrite magnet). Neither are cheap, the Beyma prolly cost more than 350 euro, the 18Sound less.
Page <1 345 |
