phase: bph18 + tham15 together : can you do it? |
tulipkapy
New Member Joined: 29 June 2020 Location: https://giupvie Status: Offline Points: 2 |
Posted: 29 June 2020 at 3:23am |
I'm designing a techno sound system the system I have a "similar turbo" stack per side: 2 speakers 1 "+8" + 15bph 4 bass 18 (18tbx100) es18bph and I also have 8 bass tham 15 (15tbx100). Can I add them to the sound or do I have phase problems, does anyone have the response curves to compare them? as you would advise me to position them, I thought of the stacks with the bphs on the side of the stage, and the thams in the center if the bass cannot coexist, will they play louder 8 tham 15 or 8 bhp 18? Thanks :) -------------------------------------------------------------------------- https://bit.ly/2VJ3dri - https://bit.ly/38rVfbc
Edited by tulipkapy - 06 July 2020 at 5:25am |
Tonskulus
Registered User Joined: 15 September 2017 Location: Finland Status: Offline Points: 425 |
ES18bph is louder >60Hz than tham15, but tham15 will go a little lower.
I would not combine these two, but rather use only tham15 OR es18 for techno. Its up to taste. Edited by Tonskulus - 29 June 2020 at 1:43pm |
king david
Young Croc Joined: 17 January 2007 Location: italy Status: Offline Points: 1324 |
You should measure the two and see how and if they Can go together. Check different filters and phase responses, set the delays and it may be doable...
