  New Posts New Posts RSS Feed - phase: bph18 + tham15 together : can you do it?
tulipkapy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tulipkapy Quote  Post ReplyReply Direct Link To This Post Topic: phase: bph18 + tham15 together : can you do it?
    Posted: 29 June 2020 at 3:23am
I'm designing a techno sound system the system I have a "similar turbo" stack per side:
2 speakers 1 "+8" + 15bph
4 bass 18 (18tbx100) es18bph
and I also have 8 bass tham 15 (15tbx100).
Can I add them to the sound or do I have phase problems, does anyone have the response curves to compare them?
as you would advise me to position them, I thought of the stacks with the bphs on the side of the stage, and the thams in the center
if the bass cannot coexist, will they play louder 8 tham 15 or 8 bhp 18?
https://bit.ly/2VJ3dri - https://bit.ly/38rVfbc
Edited by tulipkapy - 06 July 2020 at 5:25am
Tonskulus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tonskulus Quote  Post ReplyReply Direct Link To This Post Posted: 29 June 2020 at 1:42pm
ES18bph is louder >60Hz than tham15, but tham15 will go a little lower.
I would not combine these two, but rather use only tham15 OR es18 for techno. Its up to taste.
Edited by Tonskulus - 29 June 2020 at 1:43pm
king david View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote king david Quote  Post ReplyReply Direct Link To This Post Posted: 30 June 2020 at 9:35pm
You should measure the two and see how and if they Can go together. Check different filters and phase responses, set the delays and it may be doable...
