  New Posts New Posts RSS Feed - Phase in JBL dual 18”
madboffin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote madboffin Quote  Post ReplyReply Direct Link To This Post Posted: 25 April 2019 at 3:00pm
No, that's definitely an old wive's tale!
Perhaps James Lansing just started out with a magnetiser that was wired up backwards...
There may be a real explanation somewhere on the Lansing History website.
mojofilters View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mojofilters Quote  Post ReplyReply Direct Link To This Post Posted: 25 April 2019 at 4:45pm
Thanks...according to a JBL tech note that appeared at the top of a Google search using the obvious terminology (D'oh!) James Lansing had "arbitrarily" arrived at that standard early on. It was then retained  for consistency, as JBL's user base became established in the 1950s and beyond.
I couldn't find separate actual James Lansing-specific (versus JBL corporate) answer, but given his pioneering work in the field - I see no reason why the above answer would not be perfectly plausible!
I guess when (for example) we still had Soundcraft using pin 3 hot as their standard in living history, it's easy to see why these kind of industry standardisations took time to evolve.
Edited by mojofilters - 25 April 2019 at 4:50pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 25 April 2019 at 4:51pm
There's still kit out there using pin 3 hot, ffs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mojofilters Quote  Post ReplyReply Direct Link To This Post Posted: 25 April 2019 at 5:03pm
Are you talking niche mics, specialist studio products etc, or a mainstream PA brand regular folks will inevitably encounter?
I vaguely recall being warned that certain pieces of outboard are still  inherently wired that way. However supposedly it wasn't the same kind problem as the JBL issue, as for example using outboard with pin 3 hot (consistent from input to output) via an insert renders the whole thing moot.
Obviously the latter could change if we put such a piece of kit in series, in different circumstances.
