  New Posts New Posts RSS Feed - Pin Spot
Pin Spot
SamV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SamV Quote  Post ReplyReply Direct Link To This Post Topic: Pin Spot
    Posted: 13 October 2017 at 11:44pm
Hey all,
Looking for a decent LED pin spot, I've tried a couple from Amazon and none where that good. However at the last wedding they bought some along that were stupidly bright but sadly were unbranded and I've not been able to find them anywhere.
So yeah links please for any decent ones that you've used/seen before :)
mini-mad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 13 October 2017 at 11:50pm
...i know the horse has bolted but... should have took a few pictures. One of us could have used one before and snapped back with a quick reply for you. Sorry I'm not much help either.
I got given one of those ADJ 3W LED pinspots.. that's a bit crap too. But in saying that I have some flat pars that have 3w leds in them and when I use that (as a single led with the others taped over) it's much brighter and much better at lighting a mirror ball
Edited by mini-mad - 13 October 2017 at 11:50pm
SamV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SamV Quote  Post ReplyReply Direct Link To This Post Posted: 14 October 2017 at 12:05am
It was a black rectangle with a big lens on one end about 12x12x20cm, with the top corners slanted at 45dg with no mounting options that I could see. Oh and a euro plug.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 14 October 2017 at 12:08am
Could have been a makeshift 10w domestic flood light that has been adapted(?)
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 14 October 2017 at 12:11am
...maybe?
JonB67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JonB67 Quote  Post ReplyReply Direct Link To This Post Posted: 14 October 2017 at 12:46am
Its a flood not a pinspot though isn't it?
I was looking recently and came to the conclusion that everything in my price bracket was rubbish. Did look at building my own. Which was viable just need the right housing.
BJtheDJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BJtheDJ Quote  Post ReplyReply Direct Link To This Post Posted: 14 October 2017 at 2:02am
Dammit replied waffling about LED PARs rather than pinspots - all deleted
Edited by BJtheDJ - 14 October 2017 at 2:10am
It's a difficult choice, would you rather have:
A: A vegan son.
B: An OnlyFans daughter
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 14 October 2017 at 2:42am
..dont worry, it's that time of nite!
The picture was more to show the type of unit that MAY be rigged to build a pinspot with a fairly decent output and with a bunch of colours to pick from. You might even be able to stuff it in a Birdy of a par36 and get the spot you're after...
SamV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SamV Quote  Post ReplyReply Direct Link To This Post Posted: 14 October 2017 at 3:00pm
Nah none of those are bright enough and the beam is too wide. This thing was a straight beam.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 14 October 2017 at 6:15pm
SamV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SamV Quote  Post ReplyReply Direct Link To This Post Posted: 15 October 2017 at 2:29am
Have two of those and are terrible.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 15 October 2017 at 3:12am
..worth a shot.
Failing testing a whole bunch of them in a shop... do they still exsist? Ya know shops that sell lighting
