  New Posts New Posts RSS Feed - PKN H8
PKN H8
 Post Reply Post Reply Page  <12345 9>
U.Viktor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote U.Viktor Quote  Post ReplyReply Direct Link To This Post Posted: 22 April 2018 at 8:56am
Probably not only stable but this is going to be the strongest yet best sounding amp one phase mains powered!
I will have some for testing soon, let me report my findings then.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 22 April 2018 at 12:44pm
Can it do subs? :-)
I love the XE6000 on my top boxes, but on sub duty...
Post Options Post Options   Thanks (0) Thanks(0)   Quote U.Viktor Quote  Post ReplyReply Direct Link To This Post Posted: 22 April 2018 at 6:33pm
Some saying with deeper understanding in electronics that this is the biggest thing since Class-D.
djeddie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djeddie Quote  Post ReplyReply Direct Link To This Post Posted: 22 April 2018 at 8:40pm
Originally posted by U.Viktor U.Viktor wrote:
...the 100A one phase mains connector bit strange
100A? At 240V that equates to a 25mm2 cable (per conductor).
Amp size and weight might be going down, but the cables we carry is going up!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 23 April 2018 at 4:13am
Talk to me when someone has actually been able to buy one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 23 April 2018 at 4:14am
Yeah mate I need 125A 3ph just for my sub amps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote U.Viktor Quote  Post ReplyReply Direct Link To This Post Posted: 24 April 2018 at 8:42pm
Correction:
1. 100A mains for 110Vac
2.   63A mains for 230Vac..
These are the maximum line current values as far as I informed to this date.
It has fancy mains current limiter too, so theoretically *could run on ANY fuse*
but probably penalty of continuous power.
Who does remember what was the max. line current measured of Powersoft K20 on strong 230Vac? Around 30A?
Am I right?
Edited by U.Viktor - 24 April 2018 at 8:45pm
Ricci View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ricci Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2018 at 4:34pm
32A average draw is the maximum for the K20. Peak draw can be substantially higher.
This.
I inquired with PKN about the 3-Phase line and never got any response to repeated emails. There doesn't seem to be any availability in North America.
Guests View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 22 July 2018 at 11:14pm
Full spec out
http://www.pknaudio.com/H8_eng.html
Price: €3778 inc +27% Hungarian VAT | €2975 ex VAT
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 23 July 2018 at 12:45pm
Any shots of a REAL unit not a render?
Any gigs?
Peter Papp - I know you read this. I'd love to direct A-B your amp against the K20 and can do it at Dimensions and Outlook. Let me know if you want a truly unbiased oppotunity, I will gladly say which is the better unit on power etc. Not known for pulling my punches.
Edited by toastyghost - 23 July 2018 at 12:59pm
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 23 July 2018 at 12:59pm
Info etc appears to be coming slowly but steadily - anyone want to throw together for a unit??
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 23 July 2018 at 1:05pm
