  New Posts New Posts RSS Feed - PKN XE6000 AMP?
PKN XE6000 AMP?
 Post Reply Post Reply Page  <1 678
Andy Kos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andy Kos Quote  Post ReplyReply Direct Link To This Post Posted: 16 April 2018 at 1:12pm
We managed to find a small tantalum bead capacitor with legs that fits in this space nicely. A touch of glue for stability and the problem is solved permanently.
freddymendez View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote freddymendez Quote  Post ReplyReply Direct Link To This Post Posted: 16 April 2018 at 1:41pm
You got a link to the part please Andy?
120-140 bpm, pianos and bass.
diesel, the fuel of professionals.
mendez/manchester
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andy Kos Quote  Post ReplyReply Direct Link To This Post Posted: 16 April 2018 at 2:06pm
Got them from Maplin, which might be tricky now.
But something like this should do it:
https://www.cricklewoodelectronics.com/470NT35.html
Post Options Post Options   Thanks (0) Thanks(0)   Quote freddymendez Quote  Post ReplyReply Direct Link To This Post Posted: 16 April 2018 at 2:24pm
Cheers Andy.
Have you had a play with temperature calibration? Do PKN have any instructions?
If you go to temp calibration menu and when it says "enter password" press both jog wheels in then up and down on both sides...
mendez/manchester
U.Viktor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote U.Viktor Quote  Post ReplyReply Direct Link To This Post Posted: 16 April 2018 at 2:32pm
We have put these capacitors into old PKN amps as replacement, there is just 3mm room so therefore the 2.5mm thick component:
https://eu.mouser.com/ProductDetail/TDK/FG11X7R1H105KNT06?qs=sGAEpiMZZMt3KoXD5rJ2N5U4Cys%2fUpTlw6%2fxjRoXxMS%2fMYe1Syt8xQ%3d%3d
This problem has been eliminated several years ago. Normally the temperature calibration never needs re-calibration.
We have several 'running in the field' XE4000, 2500 since 2006 without need to touch anything.
Edited by U.Viktor - 16 April 2018 at 2:36pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andy Kos Quote  Post ReplyReply Direct Link To This Post Posted: 16 April 2018 at 2:43pm
If you put the capacitor 'in the hole' , you have a little bit more than 3mm, as a small capacitor can sit inside the hole between the wires.
Post Options Post Options   Thanks (0) Thanks(0)   Quote freddymendez Quote  Post ReplyReply Direct Link To This Post Posted: 16 April 2018 at 2:56pm
Thanks. I'd also be interested to know if we can upgrade the firmware of these amps, mine are all mismatched. Perhaps there is a UART exposed somewhere?
mendez/manchester
