  New Posts New Posts RSS Feed - Plan for MT208 (MT122 for 8" drivers)
jandiboi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jandiboi Quote  Post ReplyReply Direct Link To This Post Topic: Plan for MT208 (MT122 for 8" drivers)
    Posted: 22 October 2013 at 2:01am
Hi all,
I am new here and I am planning to build my very first Mid top. Does any one have a plan for MT208? Someone said that I can just use the original MT122 design and proportionate it to fit for a 8" driver however I am not sure how to do it. I really appreciate all your response.
Cheers!
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 22 October 2013 at 2:06am
the xtro plan has an 8" horn you could look at.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jandiboi Quote  Post ReplyReply Direct Link To This Post Posted: 22 October 2013 at 5:03pm
Thanks Craving! I already saw the plan however I think it is too wide for my setup.. Is it possible to make it as compact as possible?
Cheers!
smoore View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smoore Quote  Post ReplyReply Direct Link To This Post Posted: 26 October 2013 at 1:01pm
One thing you have to understand is that as soon as you change one dimension from an original plan, it is not nearly the same thing as the original (other than very small changes)
 It is the relationship between the dimensions in the horn that create the horn effect/response. So simply changing the proportion will mean a different relationship in the dimensions, and a completely different effect. Which will most likely be nothing like the original. So in short you cant really just scale any cabinet down
janovic_x View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote janovic_x Quote  Post ReplyReply Direct Link To This Post Posted: 06 November 2013 at 8:43pm
look at this:
http://mst-one.forumactif.com/t18029-8-1-mh81
8" + 1" plan
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 06 November 2013 at 9:26pm
Clap plus 1, I done a 10" version for another forum member, but need more than scaling down to work the same, it didn't play as low. don't no how he got on with the build...
lukelucas93 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lukelucas93 Quote  Post ReplyReply Direct Link To This Post Posted: 07 November 2013 at 9:04am
I have seen a 10 but not an 8 yet the results would be extremely interesting as were trying to build a really low budget system but as compact as possible :) I will be watching this with interest ! :)
Noodles, Cabs and Booze - Student life
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 07 November 2013 at 9:58am
Remember, you pay for what u get... Cheap and quality don't work...
mini-mad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 07 November 2013 at 10:15am
Cheap
small
quality
pick two....
dont get me there no harm having a bloody good go but bee is rite
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 07 November 2013 at 10:17am
Ok not entirly rite but you get my drift.
i have made the best of bad before with very very cheap gear. The EQ in line was all over the shop
